help,motor settings etc?
  • Wingnut
    • 376
    hi,i have dm800s clone with dream elite with motorised dish,all goin brill last 9months until i messed up all foreign satellites,the problem was on sky uk i went in positioner setup and fine movement to get a better snr which clearly it did go up quite alot,i wasnt sure how i save this but i saved as positioner storage number 1,then pressed exit but dish moved back again to give me the not so high snr again,anyways i keep trying but dish always came back to orignal position again,then i tried my other foreign satellites and gettin no signal at all,but if i use fine movement a little i get a signal,but i dont no how to save as when i exit then my dish goes back and no signal,but if i go back to sky uk i get signal ok ,hope this makes sense as im abit of a newbie at this,i didnt install dish and not reachable,hope someone has a solution,thanks
  • westkill
    • 2378
    did you have problems on sky uk signal then or just trying to get better signal
    or you saying should i have just left it
    • southpaw
      • 2233
      think this issue was posted couple of weeks back , the answer that worked for the original op was to use DiseqC , as the positions wont store using simple/usals
      • southpaw
        • 2233
        there you go mate , knew it was there somewhere
        ~~~~ me , i was spot on with my guess , exactly 2 weeks back
        • Wingnut
          • 376
          alright mate, yes i have now managed to get a great snr again on 28.2e but now when i select for example 19.2e i get no signal,i then must fine move it to get signal,but the prob is say i go back to 28.2e i get signal ok but wen back to 19.2e no sig,im wondering is my dish of slightly,yes that other post was about snr which just now iv managed to suss out on 28.2e but not able to view other sats without a fine move,thanks for replying back
          edit, yes westkill i shud have just left it ,but seems now im not gettin any glitches on 28.2e hd as snr is around 96% now
