dm800 cooling
  • bph
    • 48
    dm800 cooling
    hi i have a dm800 and the small fan that was supplied with it is noisy.i have a netbok cooler (5volt usb) and it works great ,the only thing is i want to connect fan to scart so it switches fan off in standby.i have tried connecting fan to scart pin 8 + and pin 4- it does power the fan but spins slowly and led on fan is very dim .if connected to usb it is bright and fast ,any ideas where i am going wrong
  • southpaw
    • 2233
    sure you got it to correct pin mate , pin 8 should pull 12v , therefore should run faster ?
    • bph
      • 48
      hi thanks for that but have checked out pins on scart and they are the correct pins i wonder if it is wired up correctly in the box ?
      • jansu
        • Oct 2011
        Won't the processor overheat if the fan shuts down when the box goes into sleepmode?
        • smoggy
          • Apr 2009
          • 12775
          you need to set aspect ratio to 4:3
          according to post 6 here http://www.digital-kaos.co.uk/forums...al-fan-186851/
          if it works don't forget to thank bugsy while your there
