Anyone Know how to add a Satellite on DE BH 133
  • Rickh Hoe
    • 5
    Hi, Hope someone can advise me on this.
    I've read through many posts and forums but with no success.
    I put DreamElite Blackhole 133 on my DM800, only satellites on image are 19E & 13E. I'm trying to add or find 28e, went through menu's as I assumes I'd be able to download it from server (As I did with Previous Image...gemini) but don't seem to be able.
    I tried to ftp in 28e myself...etc/tuxbox/then puting in a satellites.xml file and doing a hard reset...didn't work so then I tried to restart... however it didn't work either....I'm lost.....any idea's
    Thanks for you time, don't know what else to do???
  • iKay
    • Apr 2010
    • 182
    first u need to obtain a valid and up-to-date satellite.xml file.. u can get one from here satellites.xml generator
    then ftp it to etc/tuxbox and reboot .. this should be able to fix ur problem
    • Rickh Hoe
      • 5
      FTP Sats
      Hi iKay,
      I already tried that and was successful, however I gave it another try,,,,no joy. I tried to take original File out and replace with all Sats then, left in original and added all sat but didn't work....so I downloaded 28e on its own again no success.
      "When the seagulls follow the trawler.....its because they think sardines will be thrown" What a quote from a Legend.
      • 00360362878
        • Mar 2010
        • 488
        why not load catseyes channel list, already has the xml file added in it. You will find it in the ipbox section.
        He updates this on a regular basis.
        So thanks to him.
        • westkill
          • 2378
          i use these channel settings on mine
          • vjb
            Up load the August E2 V hannible setting via addons on the dm.Green Button then Yellow then addons manager the Enigma 2 settings Vhannible doenload and install.Simples
