Trying to help out a member off here,can one of these be used to set up a network on the dm 800 and does anyone know what the ip address would be,cheers
Andy.
You need to use a router, thats compatible with 3g dongles. See thread below
You need to use a 3G router.. The sim card from the Broadband dongle goes into the router.. then you just connect the dreambox via WiFi as if it was a hardwired broadband router..
You need a router like the one below.. this is where the sim card goes into..
hi m8 just a small one , does it take much from your dl allowance ?? thanks
appears not. only really been using today but next to nothing i think. Picture is very stable too.
Will test it properly tonight and tell you how much it uses mate
im using three dongle now with d100 router plugged into ethernet socket. can also access the box via wifi with it
hi mate im trying to set up a similar system in ireland
using 3 broadband and a repeater to improve speed
il get the router and bm500s once ive got the broadband up and running
my question is what broadband speed are ya getting with the dongle to run this system
as i have poor broadband reception and need to know before i splash out on the router and dm500s
I have just set this up today in the front room which is bottom of house and reception isnt that great to be honest and if i have it plugged in down here i normally need to put router on window to get decent speed. If its for the laptop I normally put it in the loft room on the window and connect using wifi.
Anyway with the box plugged into dream its no where near the window and i'm not getting any freezes or glitches and I'm using the lappy too via wifi.
couldnt get the picture to come up like yours but when i get the 3 broadband and repeater should get a lot more
theres some new eu thing in now where you have to be supplied with atleast 1.6mb speed
mtv1 is a 3 rep in ireland he will no all the details
ya might be able to get sorted out with something over there aswell
