Newbie - Need help editing my channel list
  • octocfc
    • 37
    Hi All, need help editting my channel list. I'm a owner of a clone DM800 HD. I would like to be able to edit my channel list into bouquets or something like that.
    I'm a newbie on this matters ...
    Any help will be much apprecieted.
    Many Thanks
  • Curious123
    • 2591
    Download a channel settings such as the E2 catseye from the internet and dreamboxedit program and use those to manage your bouquets.
    • octocfc
      • 37
      my dreambox has a gemini image loaded on it, this file E2 will work ???
      Many Thanks
      Hi , i've just tried to receive files from my box and i get following error message:
      Dreambox response: Login successful.
      ** Retrieving file list of "/var/tuxbox/config/enigma/" **
      Starting FTP transfer
      Transfer complete
      Transfer complete
      Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/enigma/
      Check the dream path settings on the option panel to point to the correct Dreambox directories and try again.
      Disconnecting.
      Disconnected.
      Any Help will be much appreciated. Thanks
      And i received this message when i tried to send thr E2 file to my dremabox:
      Connected.
      ** Getting directory list /var/tuxbox/config/enigma/* **
      Transfer complete
      ** Sending file "/var/tuxbox/config/enigma/lamedb" **
      Transfer aborted
      Error sending file "lamedb" to the Dreambox.
      Disconnecting.
      Disconnected.
      • davvo
        • Apr 2009
        • 666
        in options click on new enigma2 settings and save
        then try again
        • octocfc
          • 37
          Hi davvo,
          that worked a treat ... Many Thanks.
          • BM300
            • 74
            Another nice program for saving and editing your channel list is DreamSet.
            It is very user friendly and has other options.
            • octocfc
              • 37
              I'm having some trouble sending a channel list to my dreambox ...
              I'm able to receive the files from the box, but when i edit it and send it back i get thr following error messages:
              Any help will be much apprecieted ...
              OCTOCFC
              • victory22
                need help ftp-ing catseye e2 file to dm800
                hi guys, im also a newbie and need help ftp-ing the catseye file to my dm800, i have dreambox control center but dont know which folder the updated file is supposed to be transferred to...
                please help?
                • Curious123
                  • 2591
                  please help?
                  Dwonload Dreamboxedit from internet and use that to send your files to your box. With this program there is no need to remember where all the files go as it will sort it out for you.
                  • khalsa techi
                    • Feb 2012
                    • 13
                    I'm using DreamboxEdit 3.0 and get the below Error
                    Connected.
                    ** Retrieving file list of "/etc/enigma2/" **
                    Transfer complete
                    Transfer complete
                    Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /etc/enigma2/
                    Disconnecting.
                    Disconnected.
                    PLEASE CAN SOMEONE HELP, I've searched the forum and tried to carry out the instrucations to edit the file but it does not work for me - WHERE AM I GOING WRONG, your help is appreciated.
                    • southpaw
                      • 2233
                      When you browse to the saved settings ( ie sgtflipflops ) , make sure you open the folder, not just point at the folder , you need to point at the contents of the folder, hope that makes some sense
