bt home hub2 ip setting problem
  • junger
    • 200
    Hi All
    Using a drembox 800hd with a bt homehub2, when in the network test i get
    DHCP disabled
    ip address unconfirmed
    name server unconfirmed
    any ideas why
    thaNKS JUNGER
    If only I had more time that I could waste
  • wilf
    • 1618
    i would suspect you have the settings wrong in network? unless you are setting up static ip in box, you should leave it set for use interface....yes and use dhcp....yes
    • junger
      • 200
      Sorted, thanks, the router gateway was incorrect, bt home hub, what a load of sh**e
