DM800 Service unvailable
  • spyrogo
    • 33
    Decided to update the bouquets this morning as a few channels have moved since the B16MCC V3.5 I had been using. I found a file on here B16MCC E2 BOUQUET 17.11.10 so uploaded that this morning with dreambox edit, and now I get
    "service unavailable check tuner configuration"
    I have checked the tuner config and it looks ok, if I do a manual scan then I do get whatever channels I scan for on the TP. I have also tried to upload the old channel list back and that is also now not showing the channels, they are all sort of greyed out.
    Any ideas?
    SP
  • spyrogo
    • 33
    In the end I did a full rescan and now all the channels are working ok, very strange
    SP
    • opsmonkey
      • 5379
      the satellites.xml file will have been different probably...
      once you rescanned the sat they will have matched
      • spyrogo
        • 33
        Cheers, had a look through and 95% of the channels are there, but still a few greyed out, you think I need to manual scan those ones that are missing?
        SP
        • opsmonkey
          • 5379
          yes mate manual scan the transponders
