Help
  • craig0069
    • Oct 2010
    Help
    ok hi guys i got a dm500 i like this boxes so much so i upgraded to dm800 hd
    iam using dcc but on this box in the ccam.cfg there is 0-5 to chose from for my line on my 500 there was only 1 if you know what i meen
    any help its driving me mad
    thanks craig
  • norry
    • Nov 2010
    • 12
    You'll have a CCcam switcher plug-in installed. What this means is that you can have up to 5 configs on your box and are able to switch between them, but only 1 is active at any one time. The plug-in alters cccam.cfg behind the scenes for you, so if you choose cccam_0.cfg it will copy the contents of that file into cccam.cfg, similarly for 1 to 5.
    If you only have one config then just make all 5 the same or never swap profiles after you have it set up.
    Not sure if posting this is against the rules or not, if it is accept my apologies, delete this post and I'll have learned my lesson for next time that even discussing cccam plug-ins is not allowed.
    • dctyper
      • 2539
      delete all except the cccam.cfg
      the others are backups that are not used
      dc
