DM800 eSata hdd
  • DSmooch
    • Sep 2009
    DM800 eSata hdd
    Hi everyone,
    just switched to DM800 from ipbox9000... so im kinda new to it.
    I have perterPan flashed and installed a hdd (500gb Fujicom) connected to eSata (with external power)... it's not mounted...
    i go to "harddisk initialize" and it says "no hdd found"
    Does it have to be formatted a certain way before? (tried fat32, ext2..) ...
    any help appreciated...
  • bubbles69
    • Feb 2010
    • 1150
    Check the esata cable is pluged into the mainboard, as if a hdd was previously internal fitted it maybe disconnected inside
    • DSmooch
      • Sep 2009
      thanks man but I checked.
      I event bypassed it and connected a 3'5 sata directly to the main board... also tried a WD external hdd in eSata...
      can the clone be faulty... havent come by a thread with this kinda problem...
      • bubbles69
        • Feb 2010
        • 1150
        It should always been seen in device manager as not mounted weather formated or not
        • dctyper
          • 2539
          the voltage will be different mate so it wont work
          Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
          previous life dm800hd and 500c on cable screw you nag3
          • DSmooch
            • Sep 2009
            i got a f$%^% up rev J tuner (not later than last month), the hdd not recognized... wth..
            don't buy from CrownSat.... as a conclusion...
            @dctyper
            the hdd led lights on... from usb to power cord...
            @bubbles69
            from what ur saying... its the image or the box. cuz i tried with 2 different hdd both powered externally...
            what image are u using?
            thanks again...
            • dctyper
              • 2539
              2.5" sata runs on 5v me thinks. this is what the dm800 has
              your 3.5 will be 12v so it wont work
              dc
