DM 800 clone bomb
  • oneilus
    • Jul 2010
    • 15
    DM 800 clone bomb
    HI all, i have a DM800 HD PVR
    was working fine until sunday.
    When i ppower on the box: nothing on the font panel
    fan is turning
    ethernet led is on.
    i tried to reflash it with dreamup but the box is not booting so my computer can not even access to it.
    I think that is caused by the bomb after i changed the image.
    any idea?
  • andy91
    • Aug 2010
    • 3583
    fan is turning
    ethernet led is on.
    any idea?
    What image did you have on the box??
    Use Dreamup 1.3.3.4 or another version if you have tried it and try it with null modem and ethernet together.
    Post back your results,these boxes are like this sometimes so be patient.
    Andy.
    • succuba
      • 4
      DM800 malfunction
      This could be a coincidence but when I switched on my DM800 on Sunday morning it refused to boot up also, after looking at the situation I realised that the lights on the Ethernet socket were lighting up but the front panel was dead, I have tried everything, the power out of the power supply shows 12.3v but I don't know if it supplies the required current when on load. I tried my supply from my DM500s but this did not male any differnce ( maybe because it will only supply 2A and the DM800 power supply is a 3A unit).
      The image is DreamEliteBH_DM800_72. (almost sure)
      Really stuck here and any help no matter how small would be greatly appreciated.
      Thanks for your time
      succuba
      • andy91
        • Aug 2010
        • 3583
        succuba
        Pretty sure the power supply for the dm500 will work on the Dm800 i used to mix mine ok so that rules out the power supply.
        Download a fresh image and keep trying with different versions of Dreamup.
        Sometimes putting in the power supply in and out quickly works,i had similar problem
        Andy.
        • succuba
          • 4
          Thanks for the info about the power supplies Andy, I will keep trying and keep everyone informed about the progress (or lack of).
          Everyone's input is important here.
          Thanks again
          Succuba
          • oneilus
            • Jul 2010
            • 15
            As far i remember i had the last image of gemini on it(not sure)
            Sometimes when i put in and out and in the power, the font screen panel show the DREAM logo for 1s and after disappear...
            i tried many versions of dream up and nothing happen..
            • andy91
              • Aug 2010
              • 3583
              What version of Dreamup have you used?1.3.3.4 seems to be the best but use null and ethernet together.
              I stay away from Gemini images and stick to Nabilosats Blackhole 012 or DreamElites Blackhole,try and flash one of those if you can.
              Andy.
              • oneilus
                • Jul 2010
                • 15
                I used
                1.2.2.0
                2.14b
                1.3.3.5
                1.3.3.4
                1.3.2.1
                with and without ethernet.
                the problem is still the same: the box is NOT booting at all so dreamup can not acces to it.
                • andy91
                  • Aug 2010
                  • 3583
                  I used
                  1.2.2.0
                  2.14b
                  1.3.3.5
                  1.3.3.4
                  1.3.2.1
                  Have you tried it with a null modem cable??
                  Andy.
                  • oneilus
                    • Jul 2010
                    • 15
                    i used this cable before to flash my box and it was working fine.
                    is it the right one ?
                    • andy91
                      • Aug 2010
                      • 3583
                      Looks ok as long as its not a cross over cable.
                      Take it you are starting Dreamup first on pc then adding power to Dreambox??
                      Another option is to try and flaash with the browser option.
                      • psats
                        • 823
                        I used
                        1.2.2.0
                        2.14b
                        1.3.3.5
                        1.3.3.4
                        1.3.2.1
                        read this thread it has been coverd before.
                        useing the search function finds you lots of info if you have probs that has been coverd before.
                        • andy91
                          • Aug 2010
                          • 3583
                          http://www.digital-kaos.co.uk/forums...-found-148229/
                          No mention of CA IN thread his box wouldnt boot up so if you know of a way please tell.
                          • oneilus
                            • Jul 2010
                            • 15
                            this is not my problem: i dont have any error message like Err01: NO CA FOUND
                            I run dreamup with null cable conected to pc and the box.
                            i press connect and then i plug the power to the dreambox...
                            nothing happen then
                            • psats
                              • 823
                              nothing happen then
                              if you have the correct null modem cable all the dead ones ive seen still boot
                              useing the info in that thread or this one.
