DM800 wont boot or flash
  • seabeesty
    • Nov 2010
    • 6
    hello everyone,
    I am new to the world of satelite boxes having bought Dreambox 800hd from fleabay and am in need of help
    the box worked for about a week with some crashing and green screens and now all it does is have yellow/green lights and fan noise.
    downloaded universal dreamup v1334 and connecting box by null modem cable to pc.
    all i get is "connection prepared, now switch on dreambox!" have tried with and without holding down silver power button. apart from noise of fan and green/yellow light nothing happens
    can anyone help me please. is it dead ?
    colin
  • plonker
    • Mar 2009
    • 18
    dreambox
    hi when you have conetion established on dreamup pull the power lead out of the dreambox wait about 10 secs then plug the power lead backinthe box it should then start loading the bootloader wait till the flash button turns blue when you put your mouse pointer over it click flash then select the nfi file you want double click it then it should flash the box waite till its finished disconnect dream up unplug the power lead from dream box waite 10 secs plug power back in should start booting load all your default settings away you go hope this helps plonker
    • notts_alan
      • Mar 2009
      • 17
      you are better flashing with the web browser method , works every time on original box
      • seabeesty
        • Nov 2010
        • 6
        thanks notts_alan
        dont think i can flash with web browers as the oeld display isnt working to give an IP address
        how can i find IP address without the oeld display ?
        regards
        • plasterer
          • 1631
          If its connected via the router
          Try 192.168.0.1
          All the way upto 192.168.0.9
          One of them should give you acsess
          Hope this helps ..............Paul
          PAUL
          • Phantom98
            • Dec 2010
            Older DreamUp
            If You have a clone, try to use an older version of DreamUp.
            • seabeesty
              • Nov 2010
              • 6
              i tried the ip address route, in dream up i get the message, "invalid pc-ip, please select a valid one"
              when i try the ip address in the brower as http://192.168.0.1 up 9 all i get is internet explorer cannot display the web page
              also tried various versions of dream up
              now i am stuck again.
              can anyone help further
              many thanks
              • opsmonkey
                • 5379
                you need to find out the correct ip address then, the error you are giving is due to the wrong ip address being inputted..
                not all routers assign the same ip path.. for example my old router assigned 192.168.1.x to devices where my new one assigns 192.168.0.x
                you need to log into your router and see what address it has assigned to your dreambox
                if you dont know that address go into your PC to the following:
                Control Panel -> Network & Internet -> Network Map
                There you will see your router listed as Gateway, right click over Gateway and select "View Device Web Page"
                this will take you to your router log in page
                Failing all that you will have to Flash the old fashioned way with a Null Modem cable
                • seabeesty
                  • Nov 2010
                  • 6
                  many thanks for that, very helpful
                  i got on to my router and saw the various ip addresses for wireless printers, ipod etc but not one for dreambox
                  dreambox connected to router by an ethernet cable so i would expect to see an address for it
                  any suggestions ?
                  colin
