hi i wanted to know if there is a black hole firmware for a dm800 ....and i also wanted to know how to put the firmware on the box
is there a BlackHole firmware for a dm 800 clone
yes, check the dl section its nabilosat v12
shut down the box, then power up again while holding the power button on the box, this will give you an ip address. put this in your web browser. click flash and use the file you downloaded
dcWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
chossing an image is down to preferenceWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
screw you nag3
