I want to run DM800HD and a protek STB from one motorised dish to serve one TV. Can someone direct me to a post or explain how please. i have tried to loop through but not working. Both boxes are set up for usals. Thanks in advance
Two Boxes one dish
Just have another line put in.
Ive a Dreambox downstairs and one in the bedroom.
Only the downstairs Dreambox will move the dish so you have to watch the same sat on both boxes.
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
thanks Andy. Do you mean put another coax line to the motor ie heve separate lines from motor to each box. Both boes are beside the TV in same roomComment
Thanks Tango. I just thought there might be a more easy to operate system. My boxes have separate connections to Tv. So if boxes are A which can move dish an B is second box direct to twin LNB. When I watch B and want to change satellite i have change tv input to A ,change satellite, then change input of TV to B and select channel on B.....life is very dificult. What do diseque(spell) switches doComment
That is the easy way,2 lines coming from a twin or quad Lnb but only one will drive the motor.Thanks Tango. I just thought there might be a more easy to operate system. My boxes have separate connections to Tv. So if boxes are A which can move dish an B is second box direct to twin LNB. When I watch B and want to change satellite i have change tv input to A ,change satellite, then change input of TV to B and select channel on B.....life is very dificult. What do diseque(spell) switches do
I tend to stick to Sky Uk in my bedroom but only one line will drive the motor which is my downstairs box.
