hi guys has any one any idea how to add picons to newenigma2 for the dm800hd i'm not having much look
adding picons to newenigma2
Tags: None
as per sgtflipflop instructions:
Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively:
/usr/share/enigma2
NOT recommended, because of limited capacity of the flash memory
/media/hdd
HDD will keep running indefinitely and may affect image performance
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Picon will display immediately on zapping, no further setup required!
Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly -
hi mate thanks for the guide but i have tried all location and still cant see piconsas per sgtflipflop instructions:
/usr/share/enigma2
/media/hdd
/media/cf
/media/usb
has any one with the newenigma image succeededComment
think i'm getting closer with this
now when i open dreambox edit i can see all the picons but still when i send them to the dreambox there not there ?Comment
Hi, I dont know whether you have checked the following:
-For a HD skin, the Picons should be 100 pixels x 60 pixels and bit depth 8, 256 colours.
-The picons must be sent to the file location as set in Newnigma2 (I use a CF on my DM8000) This can be done by Dreamboxedit but you must set the path to the above location. Dreambox edit assigns the service reference to the Picon name.
-For the picon to work, it must be named with either the service ref. or the exact name in the user bouquet or service list.Comment
New Enigma picon resolution
MANUALLY ADD PICONS:
Blue Button > Newnigma? Services > System Tools... > Expert Menu
and here are the options for "Skin picon.." and "LCD Picon..." - change the settings with right & left-button on your remote control.
Choose the /media/cf folder in the OSD-Preferences
You need picons with channel reference style ( 1_0_19_12E_1EDC_9C_FFFF0000_0_0_0.png )
Save your sd-picons to /media/cf/picon
or your hd-picons to /media/cf/piconHD
I have also found that the folder names are CAPS lock sensitive.
Sadly I cannot install these on my USB and make them work.Comment
