settings 1 west
  • porter1
    • 559
    settings 1 west
    i have dream 8oo,running dream elite,with catseye settings,i get all the sats and the list works but when i go to 1 west the list is greyed out ,says something like check config settins,i am using advanced with each sat numbered 1 west being no 1,i have manually scanned 1 west and the list still wont work,confused
  • silkcut
    • 7
    Give this a try... You need to edit your satellites xml file. Open what programme you use to FTP. (DCC E2) The file can be found in etc/tuxbox and you will see file there satellites.xml, right mouse click on it and click edit scroll down to the satellite you need to edit and then save, for 1W you need to edit so it looks like this line:
    <sat name="Thor 5/6/Intelsat 10-02 (1.0W)" flags="0" position="-10">
    Also check 5E as it normally does the same to that satellite aswell.
    • porter1
      • 559
      cheers m8 ill have a go
      • porter1
        • 559
        ill test it after ive watched this movie,cheers
        • porter1
          • 559
          done it but hasnt changed it,still greyed out
          • RuberDuck
            • 1724
            no such satellites exist.
            there true locations are 0.8 west and 4.8 east.
            @porter1 update your satellites.xml file with a new one see if that helps.
            • porter1
              • 559
              ye will do m8 later,cheers
              • yamar1
                • 970
                thats correct, download the latesed settings to your box and all will be well.
                Faster than Faster
                • porter1
                  • 559
                  i have the latest catseye setts,but will do it again
