Bouquets not showing on DM800
  • etch
    • 70
    I am trying to transfer Sgt Flipflops bouquets to my box using Dreamboxedit which i do every time there is an update and without any problems, however now the transfer says ok but they are not showing under favorites, there is just another favorites folder there which is empty. I have tried many times without success so there is obviously something that i am doing different from before??
    Any advise on this would be much appreciated.
  • pogo2009
    • 45
    Start drembox edit again and press the reload settings button.
    • 00360362878
      • Mar 2010
      • 488
      hi etch. When the transfer is finished click on reload settings in drembox, it takes a few minutes.
      • 00360362878
        • Mar 2010
        • 488
        you beat me to it mate
        • etch
          • 70
          Thanks for the quick response guys, but i have already tried that and it does not sort the problem out. Like i have said, i have been updating my bouquets regularly but for some unknown reason its not working for me any more?? Any other ideas?
          • 00360362878
            • Mar 2010
            • 488
            Try a different version of drembox edit.
            • etch
              • 70
              Tried that too as well as older versions of the bouquets as i have had them previously. It is really strange how all of a sudden they are not showing and for no obvious reason??
              • 00360362878
                • Mar 2010
                • 488
                are you set up for enigma2 in DBE settings
                • etch
                  • 70
                  Yes, it just does not make sense! I have even thought that it may be an image problem so re-flashed the image to try that but still no change?
                  • etch
                    • 70
                    Right, after pressing reload settings button i get the following message:
                    sending reload commands
                    sending auto reload command succeeded
                    Then when i click Reboot dreambox i have just noticed this message before the box re-boots:
                    Connect error setting up telnet session for sending reload command
                    Dont know if that makes things clear for what is causing the problem?
                    • 00360362878
                      • Mar 2010
                      • 488
                      you dont need to reboot the box if it reloads properly. the rload settings is in 2 stages and normaly takes a couple of minutes, click reload settings before and after. Not sure if that will help, but I would give it a go.
                      • etch
                        • 70
                        Tried that but no good again. I do not know what else i can try? Surely i cant be the only one that has had this problem? All i am getting is a favorites folder and nothing else.
                        • 00360362878
                          • Mar 2010
                          • 488
                          Maybe the channel settings file you have is damaged, maybe get a new one and try again. It's a pain but it will be something simple. I reflashed one of my 500s this morning and it was a right arse. Be patient. Good luck mate
                          • etch
                            • 70
                            I have tried older files as well as the latest one but still cant get it to work. I have been trying all day today to get it working but to no avail. Thanks mate for all your help and if you think of anything else, please let me know,
                            • 00360362878
                              • Mar 2010
                              • 488
                              will do etch.
