DM800, no access to addons...
  • tkm18
    • Aug 2009
    • 158
    Have flashed the box with 2 different DreamElite images and both are saying 'Sorry, connection failed' when i try downloading addons via addons manager.
    Have tested and restarted the network several times.
    Images were flashed via the network, so it deffo only the internet causing the grief.
    Have restarted the router and the modem several times, its a cabled connection btw.
    Any ideas?
  • dctyper
    • 2539
    use nabilosat black hole
    dc
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    • tkm18
      • Aug 2009
      • 158
      dc
      So image problem then?
      Was gonna try a new image to see how it worked, but if its no use, fair enough.
      Cheers.
      • tkm18
        • Aug 2009
        • 158
        AAARGH......
        Fkin thing is now 'Erro1 : No CA Found'
        Already fixed this twice today.
        Box is gonna get launched out the window shortly.
          Originally posted by tkm18
          AAARGH......
          When you fix it again make sure you flash with the correct BL. How are you fixing it and breaking it again ?
          • tkm18
            • Aug 2009
            • 158
            Ive used the image i found on my HD, thought it was one i had used previous, possably a rogue one ive dl'd and not used.
            To get the no CA fixed ive been using the patched dreamup, no issues except how long it takes.
            Flashed the last two images fine, but no internet access once its setup.
            • 00360362878
              • Mar 2010
              • 488
              If you still cant connect to the internet when you are up and runnung again, it must be the router that is'nt assigning a ip address to your dm. Check your router settings.
              • tkm18
                • Aug 2009
                • 158
                Can't see what would be causing that. Doing my fkin nut in, it'll be something daft, I know it.
                • yamar1
                  • 970
                  Any ideas?
                  dream elite servers been gone for months, thats why you cant connect.
                  as dc said try nablo blackhole, same image basicly.
                  Faster than Faster
                  • smoggie
                    • 863
                    have you tried assiging a static ip addy to box? if router is 192.168.0.1 set dm to 192.168.0.5
                    • dctyper
                      • 2539
                      he has no issues connecting to the router mate
                      • yamar1
                        • 970
                        as said m8, its the image, not connection issues.
                        Faster than Faster
                        • tkm18
                          • Aug 2009
                          • 158
                          Some man.
                          Kicked in first time once i actually found a proper image for my box.
                          Cheers.
