hd pvr clone no dvi output to TV
  • thefatroller
    • Oct 2010
    • 8
    A friend of mine bought a DM800HD i assume its a clone, he was getting freezing issue's on espn hd which lead him to buy another tuner. This one sold here,
    Dreambox DM800HD DM800 Tuner - Freeze Free, Glitch Free on eBay (end time 27-Jan-11 10:19:17 GMT)
    I fitted the tuner for him and booted the box up and there was no dvi output or scart for that mater, so i put his old one back in and to my surprise still no tv output. The LCD on the box was ok and booted up and the channel was displayed(on the dm800 lcd).
    I can ftp to the box and discovered the bootloader to be 72.
    I thought the problem might be the image so i installed dream-elite-clone-bl-72-1101loader which I found here.
    Digital Kaos - Downloads - DREAM ELITE clone bl 72
    This did not solve the ouput problem and now on the Box LCD it goes through the booting sequence for a couple of mins then toggles display between DVI, SCART and YPbpr.
    Could anybody help me with a fix for this please
  • The fat man
    • 196
    Hi , I had the same problem and it turned out that I had not chosen dvi in the time allotted and i all went blank this coupled with the batteries going in the remote did not help so i replaced the batteries and when the lcd screen on dreambox showed dvi I pressed okay and all was well.
    I hope this helps
    • bubbles69
      • Feb 2010
      • 1150
      The ebay listing is for a FAKE rev M tuner sown in picture REV M should have label BSBE2-801A not 401A
      Try scart socket as the new image is cycling through the different types of out check if scart is ok?
      • thefatroller
        • Oct 2010
        • 8
        Thanks for your help with this guys but still no joy. Is there anyone on here I can send this too. To have a look for me, for a fee of coarse.
        • bubbles69
          • Feb 2010
          • 1150
          Think only people to fix are the chinese, other option is to replace the mainboard, are you sure you have checked everything? does it work fine through scart?
          • thefatroller
            • Oct 2010
            • 8
            No it doesn't work through scart neither
            • southpaw
              • 2233
              can you not put the original image back on , then when configuring it , you can view the oled screen on the box to cycle thru options , enabling you to get the output you require,
              edit , please try and put an image on containg bl76d , images can be found from this link , dont worry you got 72 , sim2.01 is the important part , and 76d images will overwrite previous bl`s ,
              Free Emulators/Tools Download (Only for NEWB DM800 SIM2)
              then view the led screen for output selection (if you dont see it on tv that is)
              let us know how you get on
              the tuner file (bcm7401.ko)may be be your issue here so 76d will update it
