I need help
This topic is closed.
  • carddreamer
    • 94
    I need help
    I have bought a new DM800 Clone, REV M, but can?t get it to work. I have installed a lot of DM800, but this drives me crazy.
    I have installed a Gemini 5.0 Patched and CCcam 2.14 and a working C-line. The same configuration is working on my other receiver (REV L3) in my house. I can?t open all the coded channels, but free to air channels is working and I have a good signal. My network is working and the C-line is working, but why will it not open the coded channels, Is there any difference in the setup, because it is the new M-tuner.
  • braindead
    • 103
    Are you sure you changed it to use the CCAM and its still not using the default emulator?
    • plasterer
      • 1631
      No should be the same mate
      Make sure you have the correct cam running
      Recheck your network settings
      Make sure DHCP is enabled
      Reboot Router and box
      See if ip changes
      Can you acsess the box via the web interface
      Also dont run the same line on 2 boxes
      At the same time ,Wont work ..................Paul
      If your Happy with the Help push the Thanx button
      PAUL
      • carddreamer
        • 94
        Network is ok,
        CCcam 2.14 is running, not Common interface.
        Ipadress is different from the other box I have.
        I have 2 working C-lines and I do not use the same C-line in the both boxes. And both lines are working.
        I normally do not have trouble with the setup in all the DM800 I have configurated, but this makes me trouble.
        • southpaw
          • 2233
          Originally posted by carddreamer
          Network is ok,
          you restarting cccam , after entering new line ?
          • carddreamer
            • 94
            Yes, all these things I have tried many times. I am wondering if the CCam can cause the problem. I have downloaded it from dreamboxtool.com. When you install a new image there is no CCcam but can this be the wrong CCcam. Or can it be the wrong image to a bootloader 76 image. I can only see those two possible issues, which can be the problem. The reason that I have the box, is that another guy could not get it to work at his home and I have the exact same problem as him, even that I have reinstalled a new image
              Respect the rules please "Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc"
              • Ken1550
                • Feb 2011
                DM 500C unable to setup
                Hi I received my Dreambox 500c today afternoon. I have been trying since to get it to work. I downloaded total spoonfed newbies guide to dreambox 500c but was no good. I am out of ideas please can someone help me
                • cunny
                  • 4915
                  Maybe you should start your own thread on the problem?
                  • carddreamer
                    • 94
                    Today I have sent the receiver with a friend, so he could find out what is wrong. But he have the same problem, it will not work and he is also a "specialist" in Dm800. Do the latest versions of the clones with bootloader 76 and REV M tuner, need a special image or a special CCCa?"
                    • NaNaNiii
                      • Dec 2010
                      • 167
                      My Dm800 Rev M came with CCcam Installed. I just had to enter my line and it worked fine
                      • plasterer
                        • 1631
                        There not listening to you ,He He ..............Paul
                        PAUL
