Best image for Dreambox 800HD Ferarri sim
  • garry1312
    • Oct 2010
    • 2178
    #16
    superb guys thnks for all the advice. that's why I love dk excelent advice every time.
    I am out at the moment but once I get back in I will be hitting the thanks buttons
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    • garry1312
      • Oct 2010
      • 2178
      #17
      also with the rytec and satmate EPG's do you need to map channels?
      • bubbles69
        • Feb 2010
        • 1150
        #18
        Hows the setup going mate,? is it all up and running... Did you get the new 801a tuner? satmate is best epg..! not sure what other images support it i only ever used dreamelite
        • garry1312
          • Oct 2010
          • 2178
          #19
          not got it yet mate its here tuesday. Dont think its that tuner bur ordered through Primusat and anyone ive spoken to have not had any glitch issues on the HD channels so hopefully thats true enough.
          • DeMasterchief7
            hello!!!!!!!!!!!
            • bubbles69
              • Feb 2010
              • 1150
              #21
              The only glitch free powerful tuner is the M 801a.. im sure he must supply the latest stuff be silly of him not too as will get a bad name... Good luck with setting it up once you done a few there such a easy box to work with... i get my 800 pro boxes from ukdreamshop and snr is 100% on most hd channels others in the 90's would like to know what you get when you get it running..
              • southpaw
                • 2233
                #22
                To be honest I don't see much between the signal levels on either box , both pro and ferrari seem to be glitch free on hd , maybe 5% better signal on pro
                Sent from my Blade using Tapatalk
                • u.s
                  • 1011
                  #23
                  Originally posted by southpaw
                  yep dead right mate, but had i booted it with the sim2 image , i would have had to use dreamup to recover from "no ca error"
                  mate, when you have a 'no ca error' you can use dreamup to do the initial bit ( the bit where it sends a bootloader to the dm800) and then flash an image from the webif.
                  • deffc0n
                    • Aug 2009
                    • 894
                    #24
                    The best Gemini
                    • garry1312
                      • Oct 2010
                      • 2178
                      #25
                      right got it today guys just came in from work and so far i have installed it with nabilo black hole 0.12 and installed my hard drive.
                      I am having trouble finding a downloads section on it to download CCcam. Also how do i set up EPG. once got it set up I will be able to provide infor on HD performance
                      • bubbles69
                        • Feb 2010
                        • 1150
                        #26
                        best to manual install it if the addons panel don't work
                        • garry1312
                          • Oct 2010
                          • 2178
                          #27
                          how do i get to the addons panel mate?
                          • bubbles69
                            • Feb 2010
                            • 1150
                            #28
                            normally green button i think then yellow
                            • garry1312
                              • Oct 2010
                              • 2178
                              #29
                              Thanks mate got it i was in the plugins. Is the username and pass still the same (root dreambox)
                              • bubbles69
                                • Feb 2010
                                • 1150
                                #30
                                yes thats it
