TM-5402 Softcams and setup
  • SatBug
    • Jun 2011
    I have a Technomate TM-5402, Sotware patched with latest unafficial patch and server add ons.
    Just nee someone to explain what SoftCam key files are for, have loaded one of these via USB, reciever confirmed successful update. But cant see what it did, do I need to do anything esle to get them to work?
  • dick b
    • Jun 2009
    • 2462
    go to 39E a lot of bulsat channels should be open with latest softcam check out novasport on 12.688 H 30000.or the arqiva channels on 12.110 H 27500 at 5E.the orf/austria sat channels on 19E as well should all be open.this will confirm everything is correctly loaded
    NB only the latest softcam will be of use all others will be out of date.
    • thijs
      • Apr 2010
      • 1096
      Also note that if you have a fixed dish at 28.2 east or old sky dish the softcam will not open anything for you
      Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
