tm5300d+usb super problem
  • radders58
    • 52
    Hi all,
    Need some advise on the tm5300d,I'm missing quite a few channels
    ie movies4men/horror channel and others.
    Can pick them all on my tm 6800hd receiver though.
    Any Ideas.....Cheers
  • thijs
    • Apr 2010
    • 1096
    did you do a rescan lately
    the frequencies on those channels do change from time to time
    Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
    • radders58
      • 52
      Yer rescanned today but still same,I have a patch from sept 09. Should I install phantompatch 147p 12/1/11 ????
      • thijs
        • Apr 2010
        • 1096
        you can try that but i don't think that will make any difference
        the tuner on the 5300 would not be as sensitive as on the 6800
        as far as i know ,if they worked fine before maybe the dish is a bit out of alignment or lnb dirty or old and needs upgrading
        • radders58
          • 52
          Cheers,will try the patch and if no diff will look at the dish.
          • harryharris
            • Aug 2010
            • 73
            i have same box & have no problems picking up any of those channels have you checked if anything else is working on those tp,s
            • radders58
              • 52
              Not had chance to check yet,will let you know.
