TECHNOMATE 500 SUPER HELP PLEASE!!
  • kennybrum
    • Nov 2010
    • 52
    Hi all i have a tm500 super. I have installed ur image with cccam. I have dreambox con cen when i click on ftp there are no files there i.e var, etc, cccamconfig, the page is just blank. They are on the tm500 when i press the yellow button tubox. I just want to be able to put a cline in all help would be much appreciated as this is driving me mad and the footy season kicks off next week. Please step by step instructions thanks.
  • freck
    • 1076
    Recheck your cables first,also try update the UR image by remote.
    1.Enable dhcp in network settings
    2.press lan button on remote
    3.Press blue buton
    4.Choose software update
    5.The box will flash itself and reboot.
    Choose CCcam as default cam and disable dhcp again and setup network for ftp....cant see why your not seeing the file structure on the box.
    Try it out and see how you get on.
    Freck
    • kennybrum
      • Nov 2010
      • 52
      Will give it a try
      Hi pal thanks for the reply i have done this its not the tv screen i cannot see the files it is on the programe Dreambox control that is where it is blank. I will give yours atry and see how i get on thanks.
      • kennybrum
        • Nov 2010
        • 52
        Still a prob
        Ok i done that the box updated turned off and turned back on. How do i setup the network for ftp step by step please. I know i am close but if you dont know its hard. I just want to be able to see the files on my DCC so i can add the c enil. Thanks.
        • freck
          • 1076
          Networking:
          Part 1 no router for those who have two machines (pc + dreambox / RJ45 cross)
          Part 2 with hub: Directions for those who have a hub: (pc + pc + dream)
          Part 3 with modem router:
          Networking Part 1:
          With the Dreambox remote: menu button / setup / expert setup / communication setup
          IP: 192.168.0. (Eg 4) DHCP unchecked (unchecked for dhcp: ok button before to change the ip, or no access)
          Netmask: 255.255.255.0
          Type lan Name
          server: 192.168.0.1
          Gateway: 192.168.0.1
          Enable network checked Green button (apply)
          On the pc
          1. start / connect / add a network connection and next next next
          2. Create an IP address on the NIC: Local Area Connection / Properties / Protocol TCP.IP / property
          3. Use the following IP address
          4. IP Address: 192.168.0. (Eg 1)
          5. Mask: 255.255.255.0
          6. Reboot the dreambox (remote control button on the top right, push 3 secs click on restart).
          Now we ping the dreambox:
          1. start / run / cmd / ping / 192.168.0.4
          2. Or a good program too small to see if everything is ok, DCC:
          3. Open the program and click on the top left on configuration.
          4. A window with a pc, a router and a dreambox s poster.
          5. If the dreambox is connected directly to pc (RJ45 crossover) right click on cross at the top left, type in the tab below and click pc 192.168.0.1 reconnect,
          6. then click on the tab below the dreambox, tapes 192.168.0.4 and click search, as choosing window displays the IP 192.168.0.4.
          7. If everything is ok green banner that links the dream to the PC
          Networking Part 2:
          1. With the Dreambox remote: button menu / setup / expert setup / communication
          2. setup IP: 192.168.0. (Eg 4) DHCP unchecked (unchecked for dhcp: ok button before want to change the IP, otherwise no access)
          3. Netmask: 255.255.255.0
          4. Type lan
          5. Name server: 192.168.0.1
          6. Gateway: 192.168.0.1
          7. Enable network checked Green button (apply)
          8. Reboot the dreambox (remote control button on the top right, push 3 secs click on restart).
          9. Now we ping the dreambox: Start / run / cmd / ping / 192.168.0.4
          10. Or use DCC to see if everything is ok:
          11. Open the DCC and
          12. click on the top left on configuration
          13. choose top left switch / hub Ip pc:
          14. click on reconnect: 102.168.0.1
          15. Dreambox tapes IP: 192.168.0.4 click seeks
          16. Nothing to add a hub, a green strip that connects pc a dream and a hub to appear
          Networking Part 3:
          We will assume that the router is configured, and has the IP 192.168.0.1 (and of course it is connected with RJ45 right to your dreambox)
          With the remote Dreambox: Button / menu / setup / configuration expert / communication setup.
          * IP: 192.168.0.4 (dhcp unchecked .. click ok on dhcp to unchecked power and change of IP)
          * Netmask: 255.255.255.0
          * Type: Lan Name
          * server: 192.168.0.1 (router becomes name server comment)
          * Gateway: 192.168.0.1
          * Enable network: checked Port: 80, and green button to save
          * Reboot the dreambox (remote control button on the top right, push 3 secs click on restart).
          1. start / run / cmd / ping / 192.168.0.4 Or use DCC for s'assurrer that everything is ok;
          2. Open the DCC, and click on configuration (top left of the window) Below pc, click on reconnect
          3. Below the dreambox tapes: 192.168.0.4 (and seeks click)
          4. Below tapes router: 192.168.0.1 click seeks A green strip, which connects a dreambox pc and the router
          Freck .........with thanks to Pyrotechnic
          • kennybrum
            • Nov 2010
            • 52
            connection ok but still probs
            Hi again thanks for your time, dcc connect fine bothe the green lights on the bottom of dcc are green so the connection is ok. The problem is that on dcc when i click ftp there does not seem to be any files for the dreambox on the left hand side of the computer screen. I have them on my dreambox how do i transfer these files so that they are showing on the computer so i can add the cline. Thanks for your time this is realy appreciated.
            • Barryboy
              • 38
              I don't know anything about the TM500 but does not mini web work with it if it does you can add your cline with that?
              Again never used dcc but every ftp program I have ever used reqire you to enter the ip address, host name, and password, to log in it also shows a log and confirms you are logged in
              • kennybrum
                • Nov 2010
                • 52
                Barryboy Big High 5 for that 1 mate, top of the pops i have driven myself mad for 4 days this missis going mad because i took over the tv . This never went through my head done it and was up and running in 2 mins thanks once again mate.
