technomate 1000 series new patch.
  • biggie
    noob`
    is there a guide on how to insert images into box as im a kinda beginner into this
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • Aug 2008
      • 5607
      #17
      There is now such thing called images on TMs i dont think. Heres how to load the patches anyway. Download the relevent patch and extract. Download the relevent loader and extract. Connect your receiver to the pc via rs232c cable. Leave the receiver on standby. Open the loader and select the software tab. Press browse and find the extracted patch. Press ok then start then wait. Thats it. When selecting a channel which should open via patch wait if the scrambled sign comes up and wait for the auto update.
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • sooriski
        • Mar 2009
        Hi. As a total newbie, I hope I am posting in the right place here. We want to watch "Detsky Mir" on Hotbird, which now shows as "Viaccess" and "$" on screen. We have a TM1500 CI+ Super (Serial port, not USB - must be an early version!).
        We did get it for a short while (perhaps a test period programmed in). Then it cut off. We own no CAM or anything yet although I have upgraded the S/W from Technomate early on. Pointers as to what to do next would be really appreciated. Best wishes to you all.
        • krazylegz
          • 2834
          #19
          upload the latest firmware from this thread http://www.digital-kaos.co.uk/forums...s-patch-10986/ then load the latest softcam on from this thread http://www.digital-kaos.co.uk/forums...3/index22.html post no#328 then if that channel is currently open it will clear
          PS3= krazylegz120282
          • caja
            Hi Mate,
            How do i download the technomate 1500 patch file, please. It does not allow me to download it.
            Caj
            • Tommy
              • 138
              #21
              BISS, DigiTV AU, Rai, etc 15/07/09 1000D_1000D_1500Ci+_1000CI
              Fixed DigiTV AU...Tested and working
              Files
              1000D_1000D_303p
              1500Ci+_1000CI_303p
              SSSP = 9797
              Enjoy...
              All Files Can Be Found Here..
              http://www.digital-kaos.co.uk/forums/downloads.php
              • dale521
                • Aug 2009
                • 4
                #22
                technomate tm-1500 d
                hiya mate can you help me i have a technomate tm-1500d and i am wanting to patch it as it hasnt been done for a long time can you please tell me how i may be able to do it plz as not used to doing these boxes cheers dale
                Originally posted by .: JaCkPoT :.
                Everytime you patch your receiver receiver make sure you also load the newest softcam.
                You have to press 0 on the premiere portals which opens a small window which directs you to the other premiere channels.
                • benny/9
                  • 1964
                  #23
                  first you need a null modem cable and if your computer only has usb ports on it.you also need a usb to serial converter [both available at maplins]
                  how to patch a tm1500 receiver with a null modem cable
                  [1] you need a null modem cable [female to female 9 pin ends] if you use a laptop you also need a usb to serial converter if your laptop does'nt have a 9 pin com port to use the cable in.
                  [2] next you need to download the v187 loader panel
                  [3] now download the latest patch for your tm model
                  you must use the correct patch they only work on the correct receiver.
                  [4] now that you have all the above and you have your receiver set-up and all the satellites and channels with the free to air channels opening.
                  [5] first open the zip folder and take the patch out ready to load on your stb: if you download to your desktop, after you have opened the folder you will see the both the folder and the patch on your desktop the patch is now ready to load onto your receiver.
                  [6] leave your receiver on standby and connect the null modem cable from your 9 pin com port on your computer to the rs232 port on the rear of the receiver.
                  [7] next open and run the v187 loader panel, and if you intend to keep your receiver patched, make a shortcut to your desktop for the v187 loader this makes it easier and quicker when you need to patch or add softcamkeys.
                  [8] once the loader has opened click the browse button and window open for you find the patch where you opened it, when you find the patch left click on it and then click save on the window, this will now close and load the patch on the v187 loader panel
                  [9] next set the loader at the top of the panel to software and download.next click auto detect and a small panel opens with version detected, click exit on it and then click connect on the panel and the small panel re-opens, then you click start on this panel and wait untill the patch has loaded fully and you will see erasing-writing etc: wait untill everything has compleated and it says finished. click finished and exit the loader panel. your receiver is now patched.now turn your receiver on and check that the channels are open.
                  [10] if other providers channels dont open you will need to enter the softcamkeys file to open the channels, you do this the same way as patching. after you set the loader panel to keys before useing the softcamkeys file. and then follow the same procedure as patching.
                  [11] finally you have now patched and got the channels open,
                  Please Read Carefully!
                  • dale521
                    • Aug 2009
                    • 4
                    #24
                    oops sorry pal its the technomate tm-1000d sorry is it just the same and also what it the latest patch i have got the loader and also i have got 1000D_1000D_303p_14-07-2009 is that the latest one and will that load channels aswell ye cheers dale
                    • dick b
                      • Jun 2009
                      • 2462
                      #25
                      Yes mate you load the 1000D just the same and it should auto update the channels, remember there is a time lag and you have to wait a few minutes for the channels to clear.
                      • dale521
                        • Aug 2009
                        • 4
                        #26
                        technomate tm-100d
                        ok mate ta for help may i asked i have just been told by some one i can not use this box with my telewest connection with no dish is this true cheers dale
                        • karub
                          • Aug 2009
                          #27
                          it dosent let me to download ot
                          • karub
                            • Aug 2009
                            #28
                            i cant download it
                            i cant download it
                            Files
                            1000D_1000D_303p
                            1500Ci+_1000CI_303p
                            SSSP = 9797
                            Enjoy...
                            • dick b
                              • Jun 2009
                              • 2462
                              #29
                              Yes its true the TM1000D is a satellite box and you need a dish.
                              • dale521
                                • Aug 2009
                                • 4
                                #30
                                technomate tm-100d
                                so i cant use it then with out a dish cheers dale
