7w available again
  • mdt
    • 3034
    #31
    Originally posted by Adam_UK
    How can you get it? i am in west yorks with 1.1 m dish and I get zero channels
    a 90cm gregorian dish has probably got more gain than your 1.1 dish. if the dish is a triax then its not quite 1.1m. when recieving out of footprint satellites its really pot luck as to whether you can recieve it as there are no real consistancys in signal levels and according to the footprint we shouldnt be recieving anything at all in the uk with normal sized dishes. regards mdt
    • mjon
      • 58
      #32
      I must admit guys since my 1st post signal strenth has dropped, weather dependant probably, crap saturday good sunday and crap today.
      I have atempted to attach some pics.
      At one point i had over 300 hundred channels, but i have deleted numerous transponders (nothing on I am interested in watching) I am into films, premier league football prefreably in HD and news feeds, so i have to keep the txps down,
      • digicon
        • 8261
        #33
        had my ladders out at the weekend as a bit slack on the work side got my meter on the dish did some tweaking and a full scan later brought me 670 channels in both SD and HD noticed that a few of the OSN HD movie and sport channels have moved over to the new sat so thats good news.
        Should be picking up nearer 1000 channels but living near a busy main road road does not help with interference.
        • Nutsandbolts
          • Oct 2011
          • 1168
          #34
          HI. Should a TM5400 SUPER be able to pick up these channels in London???. Also what about satellite AMOS at 4 WEST, any sign of life?? Regards.
          • digicon
            • 8261
            #35
            You should be able to pick these up in london no problem depending on your location and what type of RF interference you may have around you like streetlamps, Overhead power and BT lines these all factor.
            The TM5400 has a great sensitive tuner and should give you a good margin over one of the E2 receivers
            • Nutsandbolts
              • Oct 2011
              • 1168
              #36
              Hi. Thanks for the info. I will try again tomorrow to see if there any sign of life on planet 7WEST.
              • blueflash234
                • Mar 2009
                • 904
                #37
                could they be improving the signal because what happened with the portsmouth court case that they are going to try and flog there sat footie coverage here??
                • didje
                  • Nov 2011
                  hi
                  i search patch for technomate 6800 HD. Thought that the last is version 6.96, and mine is 6.91. Thank you
                  • Manic01
                    • 5117
                    #39
                    Originally posted by didje
                    hi
                    Look in correct section.
                    Download center
                    This is someone elses thread.
                    • mdt
                      • 3034
                      #40
                      Download center
                      ive just tried the link and there are no files for any stb. regards mdt
                      • thijs
                        • Apr 2010
                        • 1096
                        #41
                        Download center is slowly getting filled with files again give it a few day's
                        Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
