cyfra+ on technomate 7102
  • dicey2
    • Dec 2011
    • 8
    Guys
    Just bought a cyfra+ card from here Satsklep / CYFRA + torecevie canal+ on hotbird.
    I belive its a mediaguard card whatever that means???
    hotbird is working because i can view the fta stuff from hotbird
    I have a technomate 7102 receiver
    I assume i just stick the card in the slot and it should work? But it doesnt. And i even turned the card over in case i put it in the wrong way
    Now im new to this so if im doing something wrong or missing out on something please let me know!!
  • rigsby71
    • Mar 2009
    • 676
    Hi, I don't know much about that receiver but just make sure
    you have the latest patches & files for it, then you will have more chance of the card opening.
    Also, i have just looked at the website & for a 13 month card it is ?156 , is that the card you got ?
    cheers
    • dick b
      • Jun 2009
      • 2462
      either your smartcard reader does not support the encryption seca/mediaguard 4 check with technomate or you may need a seperate cam,or the card may need authorising (card seller should know about that)
      • Manic01
        • 5117
        Aston cam clears as well as cccam.
        TM should clear but may need activation signal from supplier sent first.
