go back to an older patch from Technomate software online
you did not state wich model so click on your model series and you will find your models patches
Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
explain a bit more what you did what happened and what model..... what sat. what channel ect. and did you follow
1)back up channel list(in datatransfer menu press green button this creates .cndf file on usb device)
2)factory reset
3)load original technomate firmware(can be got from Technomate software online)
4)factory reset
5)load latest patch (can be got from Technomate software online)
5.1)(after this load latest addon if you did not do this before, after this 8281 will work)
6)factory reset
7)put back channellist(same as patch/firmware ok on cndf file>ok on normal) and rescan all channels in use
if you don't use this method in between patches you might get stuck with bugs/problems on your tm
cause old bits of patches/firmware may remain in your tm.
and it is very important to do factory resets ,in motorised setups make sure to take note of your longitude/latitude for USALS
and reload them before you rescan sats in use
