Extra Box
  • supervlad
    • 17
    Extra Box
    Guys i need some help here, i have a Tech 5400, and its a motor system. I've Just brought a new box, the problem is that i can't get both boxes to work at the same time. A singal only appears on 1 box at a time. I'm only using a normal spliter for the feed is this the problem ? or can i fix this problem thru the menu ?
  • krazylegz
    • 2834
    you will either need a diseqc switch or a dual lnb or similar m8...but remember only one box will be able to control the motor
    PS3= krazylegz120282
    • supervlad
      • 17
      Cheers mate, just going to pop into maplins the now.
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        No he wont, a diseqc switch is only used if you are trying to connect two or more receivers to the same box, your splitter should do the trick how it currently is but the channel you view must be in the same band as that on the other receiver...why dont you just throw the splitter and just use the loop out function?
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • alunfennell
          • Oct 2008
          • 1525
          It would be as a cheap to go and buy a twin or Quad Lnb on Eb*y and just wire directly to your new receiver.
          Regards:
          Alun
          **The Worlds Best Interactive F1 Strategy Game**
          • supervlad
            • 17
            Its werid mate, as soon as you change the channel on one of them the other goes off. I'm only changing the ch's on the same sat so i thought it would work. I'm going to give the loop out a try.
            As for the Dual LNB, the problem is that i live in the bottom flat and the dish is on the roof, i had some profeesionals fix the system orginally but thought it would be simple to add a new box.
            Cheers for the help guys.
            • alunfennell
              • Oct 2008
              • 1525
              supervlad a splitter will only work if you intend watching channels from the same transponder if you dont one receiver will stop reponding, you will have to buy a twin LNB for your satellite dish to make both receivers run independently.There is no other way.
              Regards:
              Alun
              • .: JaCkPoT :.
                • Aug 2008
                • 5607
                You need a normal splitter, a diseqc switch is used when more then one one dish is being connected to one receiver
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • supervlad
                  • 17
                  Right mate, i'm almost there, just to make one thing sure, when you say the same band to you mean the same Frequey i.e either 11... or 12... or do you mean the H or V ? I played around with it for a while and i'm getting some ch's but not others.
