technomate 5400ci+usb need help please
  • tempo123
    • 344
    #16
    When you mean factory reset it is just doing the following: main menu- system setting- factory reset- enter password 0000- factory reset.....
    because I have done it and it seem only to have deleted all radio and tv channels.....when I rescan hotbird I seem to still wacth the seca scrambled channels from the previus patch?I dont get it!many thanks
    • benny/9
      • 1964
      #17
      that is what a factory re-set does it clears all the channels and settings. like time, language,satellites.motor settings etc: from the receiver along with any software glitchs that were giving problems from the receiver it does not remove the software or patch and as you say when you re-scan you can open the chns again from the patch, [the purpose of this scan] was to try to clear any receiver problems that were stopping your receiver from recognising your memory stick, have you looked to see if the memory stick is now recognised? but as your dish is fixed on hotbird 13e once you
      get this problem sorted out you need to think about getting the system motorised to get the best from it
      Please Read Carefully!
      • tempo123
        • 344
        #18
        Hi Benny/9, thank you for all the advice that you gave me.....last night I finally load succefully pacth and softcam!There was a problem like you said about the receiver recognising the pen....after trying different things I try to play some mp3 and the receiver did it....after that I try to load the softcam and the receiver recognised the softcam file and I uploaded to the pen the channel list....thanks God all back to normal!
        Many many thanks for your help
        • mumsam
          #19
          Hi can someone help me? I have a tecnomate 5400, it didnt come with any leads. I have been told i need a lead and a cam card? what is this? I am receiving a few channels, but the rest are coming up scrambled. please help.
          • frost40
            i did this to patch my box
            can i just add that when i patched my tm5400ci+ super it would not see the softcam file either,after resetting the box in the menu i retried the softcam and it recognised it immediately and worked 100% maybe some boxes need resetting after the patching and the softcam loading......just a thought
            pete.
            • dick b
              • Jun 2009
              • 2462
              #21
              hello mate,
              you will have to let us know a bit more about what you are trying to do,what sats you can get,what channels you want,etc.
              If its a lead for patching your after its a NULL MODEM lead you need they are cheap enough on the net.
              but if you have a usb you can patch without a lead
              • coin
                • Sep 2009
                • 9
                #22
                Hi Benny/9,please help I have patch my TM-5400 CI+USB super.When I try to download the new softkey off the sticky it keeps taking me to a blank page so I cannot dow load the file.What can I do to get this file.Thankyou.coin.
                • bosvelt
                  • 262
                  #23
                  you have to unzip the softcam, try using mozilla browser if you cant get as far as unzipping, also you may want to try unzipping it using winrar.
                  Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
