re: 28.2? East Channel List for TM5402, BM7000s, DrHD F15/D15
Is it running on one side of a shotgun cable. If so you may need to get a good quality single coax. I know the have been a couple instances where a bm7000 won't run on shotgun but is fine on single
Thanks mate. I just turned off all 3 other receivers connected to the same dish and the channels now work. Yet if I turn on just one of the other 3 devices it will cut out. I hope I can move the LNB cables around to get it to work, if not, I am stuffed with a device I can't use as Sky Sports 3 HD is one of the main channels I need.Leave a comment:
You can get a better lnb but I think you will find by putting the tm on another output from lnb it will be fineLeave a comment:
I have a Octo LNB as I have 2 Sky HD boxes with 2 inputs each, and a PC satellite card, and the 5402. I think that means I must have 2 sockets free on the LNB.If you have a quad lnb you will have two middle ports and two outside ports. Make sure the tm is on one of the middle ones and if it already is put it on an outside 1. As I said my vu works perfect on a port that my tm does not get hd channels with a vertical polarization. You will find all the channels you have listed we be on the vertical.
If the above option doesn't work, can I get a better LNB or won't that help ?Leave a comment:
If you have a quad lnb you will have two middle ports and two outside ports. Make sure the tm is on one of the middle ones and if it already is put it on an outside 1. As I said my vu works perfect on a port that my tm does not get hd channels with a vertical polarization. You will find all the channels you have listed we be on the vertical.Leave a comment:
Aha, you know what I suddenly thought the same after I posted it, as blind search would not find those channels either, or manually adding them. The odd thing is though that my Spiderbox 9000 has no problems with those channels using the same LNB wire. Weird. I have 2 Sky HD boxes and now the 5402 coming from the same LNB. The Sky HD box has a replaced PSU.
I will try what you suggested about making sure the cable is from the inside connector. By this do you mean the one closest to the dish ? Any idea why this may be ? Strange that my Spiderbox used to be fine with the same cable, shame the box broke.Leave a comment:
Nothing wrong with the list m8 the channels you have listed is almost exactly the same as the channels I had a problem with one upon a time and it drove me nuts. It is your lnb/coax that is throwing up the problem. In my case I found that if I put my tm on the outside connection of a quad lnb those channels didn't work. If I put it on one of the two inside connections it works perfect. Luckily my vu+ isn't so fussyLeave a comment:
Thanks for the list Happy Highlander. I downloaded your February list but loads seem to come up as "no or bad signal", on a lot of the HD movie channels for instance, and also on some of the BBC channels like BBC HD. Am I doing something wrong ? If the transponders have changed, any ideas how I can change them ? On the menu in the 5402 it just seems to allow me to change the PIDS and not the frequencies.
Some I found that aren't working for me. You have done such an excellent job on naming and tuning everything that I feel bad mentioning the below, but just thought it might help in case they are mistakes for future lists.........
Sky Premier HD
Sky Action HD
Sky Comedy HD
Sky Family HD
Sky Thriller HD
Sky Drama Romance HD
Sky Sci-Fi Horror HD
Sky 007 HD
BBC HD
Sky Action HD
BBC Three
MGM HD
Sky Sports HD 3
Eurosport HD
GOLD
There might be others. Perhaps there is something I am doing wrong though ?Last edited by Blizzarduk; 22 March, 2013, 04:25.Leave a comment:
New lists with tp changes to Ahlebait TV, Wedding TV, madani channel, channel nine uk, Noor TV, The Gospel channel, Showcase and Showcase 2. New Channels are are more 4 HD, Twinkle TV and Sparkle TV, Geo TV is now free to air and name changes are Sky Movies Modern greats/HD to 007/HD, Sky Movies Showcase/HD are now Oscars/HD, Diverse is now arise network and Filth is now called the Mall.
With Adult
Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 adult 15-02-13
and without
Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 15-02-13Leave a comment:
Add them to an existing group by clicking add to favorite as it is already maxed out with number of favorites. What interactive channels is it and if I remember I will add them at the next updateLeave a comment:
Is there any chance of getting the interactive list put into a group as some sports show different angles.
ThanksLeave a comment:
ok all sorted see post above for channel changes
with adult
Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 adult 12-01-13
and without
Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 12-01-13
just to confirm all downloads of original files will be ok the problem was with my coax feed not the channel listLeave a comment:
New channel lists tp changes to the active channel, the word network and the pub channel. Sailing 1 and 2 and geo news international are now transmitted fta. Geo news international is now encrypted. UMP Stars, ptv prime and Renault tv have gone. New arrivals are tvx brits(on adult list), sky news arabia and 14 box office channels (don't ask me what numbers). Sky christmas/hd are back to sky 007/hd and christmas 24/+ are now movies 24/+ again...
With adult
Deleted due to ~~~~ up
and without
OK reason for deleteing is most of the hd movie channels appear to have changed settings but none of the old settings or new settings appear to work so I won't upload any lists until I can get them to work. These are the same channels I've been having problems with mentioned in another thread
best way to keep track of latest channel list
What is the best way to manage the channel list? Can I modify the list once downloaded to keep it upto date? ThanksLeave a comment:
Leave a comment:
