TM5200D-usb super error msg
  • johnheeley199
    • 5
    hello again fella's.
    sorry about this need more help.
    i tried to upload new patch but i'd not checked receiver properly tried to install TM5200D instead of 5200D Super. box replied incorrect software, uploaded new keys anyway, works perfect. then when i diddownload correct patch(5200DSuper) and tried to upload to receiver i got error msg, "error memory full" . receiver sill works ok.unscrambled channels etc. but what do i do about error msg. do i wait untill end of month and then do a factory reset or do have a better idea.
    again sorry for trouble.
  • benny/9
    • 1964
    this is the way to clear the problem
    first download the correct patch and take the patch from the folder
    ready to load on your tm receiver [this is a forced download that can
    only be done with a null modem cable cable and the v 187 tm loader]
    then you connect your computer from the 9 pin com port to the rs232 port on the rear of the receiver with the null modem cable and turn the receiver off at the switch on the rear panel now open the v187 loader and send the patch to the loader, then click connect and when you see on the loader panel [connect your receiver and turn on] you go to the receiver and turn it on with the switch on the rear panel and give it a few moments and the download should start and clear the software glitch from loading the wrong software.
    it is always a good thing for technomate uses to get a null modem cable
    as well as a memory stick,
    Please Read Carefully!
    • johnheeley199
      • 5
      thanks very much for help/response. 1 other question, does it have to be the v187 loader or can i use the technomate offical loader. if not where do i obtain this v 187 loader???
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        TM LOADERS
        you need the first loader out of the three..good luck..
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
