Dutch Channels
  • casper1
    • Jun 2012
    • 14
    Dutch Channels
    Hi All, I downloaded a patch from this forum a couple of weeks ago to watch Dutch channels but they are now scrambled again. Anyone got a patch so I can load them again? Also how can I find the downloads without having to ask you guys every time. Thanks in advance. Casper. PS. I have a TM 5402 HD and the satellite is 19.2E.
  • Carew6
    • Mar 2010
    • 212
    We are all waiting for the new softcam keys to be posted.
    • casper1
      • Jun 2012
      • 14
      Dutch Channels
      Thanks Carew. Could you let me know when you get them. Thanks again, Casper1.
      • thijs
        • Apr 2010
        • 1096
        Soon they will be gone and no more irdeto for c.nl but they have been saying that for a long time now.(over a year)
        Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
        • casper1
          • Jun 2012
          • 14
          Dutch Channels
          Anybody got any news on Dutch channels.
          • digicon
            • 8261
            You dont actually have to wait for the new keys to be posted use Technomate maker 1.5 which is where the Softcam.key file is generated from, you can try every day if you like at updating but until the keys are on the server for download its trial and error.
            Its pretty straight forward to use Download from here:
            http://www.technomatesoftware.co.uk/index.php?dir=Non%20linux%20addons/&file=TechnomateMaker1.5.zip
            • digicon
              • 8261
              With a Very Big Thank you from Zorch over at Digital Worldz here is a very good guide for the above program:
              If you have decided to download/use TechnomateMaker 1.5 then it is advisable to first copy libmySQL.dll from within the decompressed Zip file and then paste it into C:\WINDOWS\system32
              Next you will want to know how to use the program... it's very straightforward...
              Open TechnomateMaker 1.5
              Select the Softcam Keys file which best suits your particular satellite set-up... the selections are...
              MonoFeed (13.0?E)
              DuelFeed (13.0?E/19.2?E)
              Motor (45.0?E to 45.0?W)
              All (95.0?E to 55.0?W currently)
              Download TMSoftcam Keyfile
              Save TMSoftcam Keyfile
              TechnomateMaker 1.5 now asks if you want to open and edit the file
              (Alternative open/edit method below)
              TechnomateMaker 1.5 also enables you to send a new TMSoftcam Keyfile directly to your receiver via an RS232/Null Modem cable connected between your PC and Technomate receiver... however... by the time you have connected the cable... selected the Com port etc... it's really not worth it...it makes more sense (nowadays) to simply save the TMSoftcam Keyfile to a USB flash drive and then load the file to your receiver...
              You will notice that the downloaded TMSoftcam Keyfile is a Registration Entries file...
              To open/edit/search the TMSoftcam Keyfile (Registration Entries file) without the aid of TechnomateMaker 1.5 just follow the instructions below...
              Right-click TMSoftcam Keyfile (Registration Entries file)
              Select 'Properties' from the drop-down box
              Go to 'Opens with'
              Click 'Change' button
              Select 'Notepad' from list of programs
              Click 'OK'
              Click 'Apply'
              Click 'OK'
              You are now able to open/edit/search (with 'Notepad') any TechnomateMaker generated/forum posted TMSoftcam Keyfile (Registration Entries file) by simply double-clicking on the file.
              When you open the file... what you will see inside is a list of all keys that are/should be active/working when the TMSoftcam Keyfile (Regitration Entries file) is written to the Phantompatch on your Technomate receiver... the top section of the file (entries identified with 'Slot' numbers) ...these are the CAS keys... this is the only part of the file that is actually written to the Phantompatch... the majority/rest of the TMSoftcam Keyfile (Registration Entries file) is populated with BISS/DCW keys that can only be entered into the Phantompatch (BISS Menu) manually... using your Technomate remote control...
              To enter BISS/DCW keys into the BISS Menu... simply go onto the channel that you have BISS/DCW keys for... press 8-2-8-0 on the remote control and the BISS Menu will appear... select a line... press OK... then enter the 16/32 digit key... when you have finished press the Exit button... Settings were changed - Do you want to save? Select Yes
              If you download the TMSoftcam Keyfile (Registration Entries file) daily using TechnomateMaker 1.5 (as I do) then you might want to know the easiest way to find out which keys have changed within the file and which keys have been added to the file since the previous TMSoftcam Keyfile... this can be done very easily...
              Double click and open the latest TMSoftcam Keyfile (Registration Entries file)
              Maximize the file (for ease of reading)
              Highlight and copy the date at the top of the file
              Click 'Edit' on the file toolbar and select 'Find' from the drop-down box
              Paste the date into the 'Find' box and set 'Direction' to 'Down'
              Click anywhere on the file above the 'Slot 1' entry then click 'Find Next'
              Click 'Find Next' repeatedly to locate more new/updated entries (until a box appears stating 'Cannot find')
              If you feel a little more adventurous... and want to edit/update the TMSoftcam Keyfile (Registration Entries file) yourself... i.e. when you see a new key or an updated key anywhere on the internet/forum... just copy and paste the new/updated key into the TMSoftcam Keyfile (Registration Entries file) save the changes... then load the file to your receiver...
              As I mentioned at the top of the post... this is just a general guide with a few basic tips... but I hope this might help someone...
              Best Wishes,
              Zorch
              • Carew6
                • Mar 2010
                • 212
                Does anyone know whether the Irdeto keys for Canal.nl have finished for good, as the TechnomateMaker1.5 does not seem to generate any keys for Canal.nl anymore ?
                • thijs
                  • Apr 2010
                  • 1096
                  maybe after the holidays
                  • Nutsandbolts
                    • Oct 2011
                    • 1168
                    Hi. The reality is that sooner rather than later most of these channels WILL disappear from our screens unless you pay. If you go back a few years and remember how many packages were opened with softcams etc compared to today. Problem is that encryption systems like NAGRA3, BULCRYPT, POWER VU etc are proving to be unbreakable and there is more on the way.
                    Regards.
                    • footycard steve
                      • 778
                      new active softcam today.
