Hi, does anyone know if it is possible to add plugin auto boquets to a Technomate TM800HD, i have this plugin on my VU+Solo2 & also my Dm800hdSE, But am having problems adding it to a friends TM800HD, any info including what programmes to use would be appreciated.
TM 800 HD With Auto Boquets
try this older AutoBouquets UltraLite version?
it was made to be compatible with boxes that run very old enigma2 code, so should be ok on TM800.
as it only has a very basic interface for compatibility, if you want to change any options you will need to edit the plugin.py and change the required Y (yes) or N (no) settings.
if you change any Y or N settings, you will need to restart the box to apply your changes ready for the next scan.Comment
