RF Modulator output 9v ?
  • mclud
    • Jun 2009
    • 10
    Does the 6900 super transmit a 9v current so we can change channels remotely on another TV, using a TV eye etc.
    Note that it does have a rf modulator and I can see the channel on my bedroom tv, but I cannot get it to change channel with the TV eye thingymejobby.
  • gord
    • 4
    9V out is 'ALMOST' unique to SKY boxes you can use a digi ready amp to supply 9 to 12v depending on make but the return path would not work with the 6900 either you would need something like the Global tvLink Plus this comes with 2 emitters to allow control of other devices eg Video DVR etc
    I'll look you out some links if you're stuck
    Cheers
    Gord...>>>
    • mclud
      • Jun 2009
      • 10
      Yeah - I thought so, looked up the Global plus on ebay, but not convinced it will work.
      but if there is a solution out there then let me know thanks....
      mclud
      • gord
        • 4
        Have used the Global on serveral systems using various saT boxes DVDs Videos etc with no probs.
        All it does is repeat the IR from your control and pass it out the emitter so 'SHOULD' work with any IR system
        Gord..>>>
