  • rafiqvindhani
    • Aug 2009
    I have a technomatic 5004 and having patched it with the latest firmware, I need to load softcam. I have no idea how to go about this. Anyb help would be appreciated. Thanx
  • Top hat
    • 63
    Hi mate go to the stickys and open noobs guide to patching your Technomate, it explins everything there. (Stickys are higlighted in red type at the top of this page).
    Regards
    • benny/9
      • 1964
      this is how you load tm 5000 series patches/softcams/chn lists etc: with a memory stick first you download the correct software,patch etc: make sure you use the patch for your model,[ there are patches for the super and original non super models] and you can only load the patch for your model. then open the zipped folder and take the patch file out
      [you must make sure the file is out of the folder]
      before you transfer the file to the memory stick, for loading on the receiver.next to load the patch onto the receiver you put the receiver on a free to air chn then put memory stick in tm5000, USB port. and turn the receiver on next you press the green button on tm 5000 remote,next it goes to data transfer> click>ok you will now see a small file panel with the patch,highlighted then you press>ok again, and it will now download, you will see green loading bar when complete the receiver will re-boot turn off and on again,then press exit. and remove the memory stick, change channels and the channels should open.you might have to load the latest tm softcam if the chns dont open. you load the softcam in exactly the same way
      Please Read Carefully!
      • bosvelt
        • 262
        do you mean TM 5400?
        Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
