upload softcam
  • kiyimba
    • 31
    upload softcam
    How do i upload a softcam file to tm6800 i downloaded the new tm 6000_original_688_patch 14/8/09 but no change so i need to add the softcam help
  • albaniansniper
    • 132
    1) plug in your usb memory stick in to your reciever:
    2) on your reciever control, press usb button or menu
    3) main menu-usb
    4) date transfer
    5) file list: = press RED button, upload channel -
    Tm-softcam.key
    Wait for it to finish & exit.
    Hu, now Sit down and Relax
    * Dreambox 800 HD se
    * Kryptview a780
    * Triax TD110 1.1m Solid Dish
    * Birds: Eutelsat 16e/ Astra 19.2e/Astra 28e
    • kiyimba
      • 31
      6-88p patch
      i have done it but still no channels are open help i have a tm6800
      with the 6-88p patch
      • albaniansniper
        • 132
        There is no many satellite channels open, but with the latest Tm-patch for your reciever and the latest TM-Softcam.keys you can open lots of channels: Start with, Digi TV @ Thor/Intelsat 1.0W
        So, point you dish on Thor/Intelsat 1.0W and Load the latest TM-Softcam.keys
        Hope this will help.
        * Kryptview a780
        • kiyimba
          • 31
          help
          still can not get any thing on tho 1 west any more help
          • albondi
            • Apr 2009
            • 15
            Hi kiyimba
            I dont have 6800 but try to format stick + load 688 onto stick again make sure you load firmware 1st then keys.
            Al
            • dick b
              • Jun 2009
              • 2462
              Are you getting the FTA channels ok?
              you can check if the softcam loaded ok by going into menu-system info-CAS menu then look for ident 2011 on the nagra headings you should have four lines of numbers line 10/11/20/21 if lines 20&21 are just rows of zeros the softcam has not loaded.if after reloading the patch then the softcam it still wont work get back to us with as much info as possible.
              • benny/9
                • 1964
                first check if the free to air channels are open with a strong
                signal look for bbc world news chn, if this is open, then i would
                also check that the patch is turned on
                transfer the softcam onto your memory stick and put the
                stick in the front usb port on the receiver then turn on
                next press the usb button on your remote and go to data transfer>ok now you see a small file panel with the tm softcam showing on it. just click>ok and it will load on the receiver
                [do not press any coloured buttons], you only use the coloured buttons to upload from the receiver when you want to save to the files on your computer
                Please Read Carefully!
                • Manic01
                  • 5117
                  Make sure you are downlaoding not uploading!
