how to patch my technomate 1oood
  • jpr
    • Jun 2009
    • 161
    Hi, I am new to patching my technomate and just wanted some help. I have a technomate 1000d super. I got the latest update from the technomate website for my reciever. What do i do next, do i download the loader from this site and latest patch conect the cable. I had a darkman patch in it a few years back but since then i done a factory reset and its now gone. Any help would be great
  • benny/9
    • 1964
    first you need to download the latest patch for your model
    and the v 187 loader panel, factory re-sets dont remove the
    official or patch firmware you lost the patch when you loaded
    the official software from technomate.com this is how you load
    the patch and tm softcams,
    how to patch a technomate receiver with a null modem cable
    it's the same way for all models tm1000/ tm1500/ tm1600
    [1] you need a null modem cable [female to female 9 pin ends]
    if you use a laptop you also need a usb to serial converter
    if your laptop does'nt have a 9 pin com port to use the cable in.
    [2] next you need to download the v187 loader panel [this is the latest]
    [3] now download the latest patch for your model[super or original]
    you must use the correct patch they only work on the correct receiver.
    [4] now that you have all the above and you have your receiver set-up and
    all the satellites and channels with the free to air channels opening.
    [5] first open the zipped folder and take the patch out ready to load on your stb if you download to your desktop, after you have opened the folder you will see the both the folder and the patch [ a little square with a yellow face on it] on your desktop the patch is now ready to load onto your receiver.
    [6] leave your receiver on standby and connect the null modem cable from
    your 9 pin com port on your pc to the rs232 port on the rear of the receiver.
    [7] next open and run the v187 loader panel, and if you intend to keep your
    receiver patched, make a shortcut to your desktop for the v187 loader
    this makes it easier and quicker when you need to patch or add softcamkeys.
    [8] once the loader has opened click the browse button and window open for
    you find the patch where you opened it, when you find the patch left click on it and then click save on the window, this will now close and load the
    patch on the v187 or for the tm 3000 it's own loader panel.
    [9] next set the loader at the top of the panel to software and download.next click auto detect and a small panel opens with version detected, click exit on it and then click connect on the panel and the small panel re-opens, then you click start on this panel and wait untill the patch has loaded fully and you will see erasing-writing etc: wait untill everything has compleated and it says finished. click finished and exit the loader panel. your receiver is now patched. now turn your receiver on and check that the channels are open.
    [10] if other providers channels dont open you will need to enter the softcamkeys file to open the channels, you do this the same way as patching. after you set the loader panel to keys before useing the softcamkeys file. and then follow the same procedure as patching.
    [11] finally you have now patched and got the channels open, congratulations
    Please Read Carefully!
    • jpr
      • Jun 2009
      • 161
      Thanks thats a big help. I was looking for the latest softcom to put into the loader but all i can see is text to add manualy is there any latest ones on here.
      • dick b
        • Jun 2009
        • 2462
        try these but dont forget to extract 1st and to use the keys tab in the loader
        also I"d turn the AU off in the options menu.
