Help Please!!! 5200 d super usb
  • scotjen1
    • 18
    New here so go easy please.
    Brought this box today and so far think it is a superb little box.
    Need some help though i have uploaded the lateset 130p firmware but am still getting scrambled channel.
    Am pointing at astra 28. east if thats any help.
    Cheers
    Scott
  • benny/9
    • 1964
    Originally posted by scotjen1
    Cheers
    Scott
    there is only free to air channels on astra 28e you cant open the scrambled channels, for these you need a official subscription the patch cant open
    these channels. first you need your dish moving to thor 1w and you
    will get all the digi-tv channels open if your useing a mini dish thats for astra 2 then you will also need to get a 80cm dish or bigger and i would
    suggest you get a motor fitter to get channels from lots of satellites,
    Please Read Carefully!
    • scotjen1
      • 18
      I do actually have an official subscription. Does this mean im going to need the card reader for my technomate or just go get the updated box that can take the cards?.
      Cheers
      Scott
      • benny/9
        • 1964
        Cheers
        Scott
        the info with the v130 patch says the cards are working
        with this patch, is the card active? ie: have you tested it
        in the official receiver? have you left the receiver set on a
        scrambled chn to see if then opens them?i dont subscribe
        to this service i know the yellow house freeview card had
        to be updated in the official receiver from time to time to
        keep itv hd and chn5 open. and forgot to say if your model
        does'nt have a card reader then you need a cam like the
        dragon/t-rex cam to read the card the patch alone cant open these chns
        • Dado_84
          • Sep 2009
          how to input keys for Technomate TM-5200D USB
          • Manic01
            • 5117
            Easiest way is to download and extract softcam file to usb stick-then insert usb stick into receiver- select usb from men or remote-select data transfer-select softcam file-press ok-when finished - exit. You can only see softcam if receiver is already patched.
            Manual way
            How to Input Keys
            Just a little note: I see a lot of people get confused every time new keys come out on whatever Channel ( Polsat etc).
            In the Key Section ?€“ The Keys are given on ---- Line 00 or 01
            Note: Example:
            Technomate 1000/3000/5000 series
            LINE 00 .......................This is line 10 and 11 on TM1000/5000
            LINE 01 .......................This is line 20 and 21 on TM1000/5000
            Note: Example: Technomate 7755
            LINE 00..........................This is Line 00 and 01 on Techno 7755.
            LINE 01......................?.. This is Line 02 and 03 on Techno 7755.
            To enter biss keys on Technomate 1000.5000
            1) Go to the biss channel
            2) Press 8280
            3) Enter codes on free line.
            4) Finally YES to exit & save
            • 46and2
              • Sep 2009
              Standar Sky dish
              I have just moved to a property with a standard sky dish. I have just bought the technmoate 5200d super an love it, but in order to get more channels, am I going to need to replace this standard dish? I'm in Cornwall UK, and am new to all this...pointning at Astra/Freesat at the mo. Any help much appreciated!
              • dick b
                • Jun 2009
                • 2462
                your best bet for getting the most from your box will to change the dish for a larger one say a 90cm and motorize it that will give you access to a lot of different satellites,you can get all the help you need on this site.if you have a look at this quick guide it will give you some idea of whats involved, this is only my way others may be able to give you an easier way.
                • dazle
                  • Oct 2010
                  same here!
                  I'm in the same position. fell out with sky, cancelled subscription. just got technomate 5200 d usb super +
                  not got a clue what i'm doing but good at tinkering. managed to get 1000's of channels but only a handful that display, got loads encrypted and no signal
                  dish was working fine on sky package
                  any newbie tips greatly appreciated, not being lazy, been googleing for a couple of days but getting baffled by terms
                  thanks in advance for any reply
                  daz
                  • kej
                    • Apr 2010
                    • 68
                    Hi Dazle
                    You need to turn your dish towards Hellesat 2. (39 deg East bulsat) mate, theres not much open anywhere else using the pacthes and softcams, You might have to change your dish from a skp dish to min 80cm dish to be able to pick it up
                    • bluetooth1
                      • Feb 2012
                      • 4
                      TM 5200 D
                      Manual way
                      How to Input Keys
                      In the Key Section ?***8364;***8220; The Keys are given on ---- Line 00 or 01
                      Note: Example:
                      2) Press 8280
                      Sorry i also have a TM 5200 D and i dont know how to insert the keys for the hotbird satelite. I used to have another box where i just pressed mute and then exit and then it wiuld give me the option to put the keys in. But in this box is not the same and i know know how to do it. Sorry you mentioned to go to the biss channel, what is biss channel? Please help me ASAP. Thank you very much in advance for your help.
                      • dick b
                        • Jun 2009
                        • 2462
                        things have moved on since that post of 2009 you quoted although the info is still sound but very little is open on 13E with keys.pressing mute then exit still works but only on available channels. entering biss keys can only be done manually as Manic01 has outlined but only works on available channels you can get the list by opening the softcam posted in the softcam section of this board,but just in case here is a list but I think you will be dissapointed as they dont all work.the Biss key list is after the softcam keys.
                        • bluetooth1
                          • Feb 2012
                          • 4
                          Thanks for the reply. Can you tel me the steps to insert the keys in the TM 5200 D. Thank you
                          • bluetooth1
                            • Feb 2012
                            • 4
                            Thanks for the reply. Can you tell me the steps to insert the keys in the TM 5200 D. Thank you
                            • Manic01
                              • 5117
                              Same as above.
