hi (dick b) no luck with that,or is it because i need a patch to go with the softcam, thanks again,badboy1965
Latest TM6000 series patch not downloading
your box must be patched before you load the softcam
it only works with a patched box, as for 23e unless you
have a dish size of1.2mtr or bigger you wont get the channels
i'm about 14miles south of you in cheshire and i only get
the astra 3 at 23e open at certain times of the day with a 1.2 dishPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
hi (dick B) i have an 90cm dish and can pick up 109 channels on 23.5 even if i could open half of them id be happy,signal strenth is average 72 and quailty in the 80s,and if you dont mind me asking can i use any softcam as there seems to loads out there saying they open this and that, or have i got to put(only tm6800hd softcam) in thanks again,this is like being at school ,living and learning,brill
************************************************hi (dick B) i have an 90cm dish and can pick up 109 channels on 23.5 even if i could open half of them id be happy,signal strenth is average 72 and quailty in the 80s,and if you dont mind me asking can i use any softcam as there seems to loads out there saying they open this and that, or have i got to put(only tm6800hd softcam) in thanks again,this is like being at school ,living and learning,brill
with a technomate receiver use only the tm softcam
are you getting the free to air dutch chns open?
there are lots german chns in nagravision encryption
that the softcam opensPlease Read Carefully!
hi again(dick b) yes im getting the free to air dutch channels,but nothing opening thats encrypted,also no nagra,the only encryptions im getting are seca,iderto and cryptoworks,ive checked on lyngsat and entered the the frequencie to kabel deutschland which is 11.595 h 28500 but my tm6800hd telling me transponder already exist,is my dish to small,thanks for your help and time,badboy1965Comment
have you patched successfully? if you check in system information it should show you a cas/biss menu and the patch number.I"m sending the patch I use if you load that via usb followed by the latest tmsoftcam(the one I posted earlier) kabel deutchland should open.But if your dish is not big enough or slightly out you will not get it.try moving the dish while on a fta channel via the motor view control(the blue button)to get maximum quality.if you use diseqc 1.2 you can save it.then if you do a PID search of 11.635H 28500 and look for "motors tv" you may be lucky if you cant get the quality above say 57 you wont get it.even so alot of the channels are touch and go I can usually get the KINO ppv and afew others most of the time.Last edited by dick b; 16 February, 2011, 16:24.Comment
thanks (dick b) patch & softcam are in and work on sirius 4.8,but no luck getting the nagra channels on 23.5 dish not picking them up,but getting strong signal on the free to air dutch channels and all other encryptions,just no nagra,thanks again for your time and effort, very happy i learnt how to patch
