How to enter keys manually with TM600 ?
  • xpress 1234
    • Feb 2010
    • 16
    I've seen a key which I want to try out but not sure where to enter the key. I've installed CCam and also have the Dreambox Control Center so can Upload files via FTP. Please help ...
  • C_S_B
    • Feb 2010
    • 56
    Hi m8,
    just a suguestion. No need to input manual keys, if its out there someone has already put it on a key file.
    So to aid you curiosity. Open any recent key file and you can check your new key againt the list there, without accidently doing some damage to the files on your box.
    You can view your own box's keys using tuxbox commander from your remote in /var/keys/softcam.key
    hope this helps
    csb
    Glasgow
    "The Transmission of Documents via Telephone Wires is Possible in Principle, but the Apparatus Required is so Expensive that it will never become a Practical Proposition" Dennis Gabor 1962
    Hungarian-born electrical engineer who won the Nobel Prize for Physics in 1971
    • xpress 1234
      • Feb 2010
      • 16
      Thanks for your reply. What's the difference between a keylist.txt file and TMsoftcam.key or softcam.key , do they work together ? Also, after the file has been updated, do I need to reboot the receiver ?
      The guy who installed my receiver installed "underground resistance" on it, I saw how he used an option to download new keys. Is that same as getting a new softcam.key ? Could someone please tell me how to access that feature ? I've spent 10-15 min with the control, not found it again...
      I had a look in the TMsoftcam.key file and didn't see the key I was looking for so probably still need to manually add it ?
      Thanks !
      • Manic01
        • 5117
        Red button downloads latest keys.
        • xpress 1234
          • Feb 2010
          • 16
          Could you maybe also tell me how I can switch between CCam and others ? I've got a card in it and need to get the correct encryption working
          • Manic01
            • 5117
            Blue button switches cams.
            • C_S_B
              • Feb 2010
              • 56
              Press blue button. Enter pin, Highlight Default softcam. Use left or right on remote to change softcams. Save and exit.
              csb
              • Manic01
                • 5117
                You can turn pin off for blue button in latest images.
                • xpress 1234
                  • Feb 2010
                  • 16
                  I can see the alsat key downloader and can tell it to update keys. But how can I see which keys it has downloaded ?
                  I'm using DCC and looking at the /var/keys folder, some keys look very old from 2003 ??
