I'm sorry to be pain ,but really i don't have any options with the menue and i don't have any thing called digi tv, is that mean i'm using an old software?
AND I THINK THE SOFTWARE IS NOT PATCHED AS I TRIED THE 2004 THING AND IT DIDN'T WORK
at last i knew what was wrong with the usb , the problem now is i nearly tried all the patches over her but none of them work as the reciver says its uncombatable, mine is TM 5400ci+ usb and most of the patch files are tm 4500ci+ super, any help?
i know i feel like the dumest over here ,put i'm sure u guys can help.
Guys i just wanted to thanks every one over here for there help, at least now i know what u guys talking about,
i have download the patch and the softcam to the reciver and now i have whats called cas menu and biss menu, i now need to figer out what to do,
you can open some channels on 19E with patching and softcam but you will have to read and understand the thread in the "sticky" section on patching your technomate patches are available here Download center only load the patch for your exact model.latest softcam is available in the softcam section of the TM forum.
i have Technomate 4500 ci+ USB
Every time i upload the patch file to the usb and try to download it to the reciver the when i press data transfer it dosn't read any thing from the usb as its blank,i try to change the usb still the same problem,
another question ,how you turn the digi au off and what is it exactly?
thanks alot
when you get to data tranfer press ok then you are asked for password alittle row of 4 boxes appear press 0000 onyour remote then press ok and thats it now you can continue to up load patches and softcams not so hard as it seems good luck m8
thanks alot
to turn of digi au press menu on remote the main menu appears move across to sat setup then come all the way down to options then press ok new box opens come down to digi tv au press left or right to turn on or off thats all thier is to it do not be afaid to experement with your tm box as if all goes wrong you can always reset your box and have all the fun starting from scratch boys toys its agood way to learn about your box good luck m8
