channel listings tm600
  • eattheliving
    • 331
    hi all....again. just a quick query this time. When i scan astra 19.2e should i be able to see all th uk sky channels listed even tho they are scrambled?
    cheers
  • the rock
    • 217
    sky uk is on astra 28.2
    • eattheliving
      • 331
      thought so. will try and scan again to see if i can get any listings on the menu.
      • the rock
        • 217
        good luck and report back let us know how you get on
        • eattheliving
          • 331
          just done a scan on 28.2e and ended up with 10 channels found , 1 transponder searched. is this correct?
          my settings are as follows:
          freq:11597V
          fec:auto
          symbol rate:22000
          did get some settings from google which read:
          freq:11681V
          fec:2/3
          symbol rate:27500
          but when i change these settings i loose the snr and agc strengths?
          • eattheliving
            • 331
            nudge??????
            • bugaloo41
              • 1598
              Sounds like you are scanning 1 transponder and not the full network or you are not on 28.2e. Why not download an up to date channel list via the server (blue button on remote) and see what quality/signal/ber reading you get when you go through the channels.
              • eattheliving
                • 331
                thanls bugaloo41. am just doing a scan atm to see what comes up.
                • eattheliving
                  • 331
                  ok guy's , i managed to do a scan for 28.2e but only got 1 transponder. when i go into the multisat option i can select 28.2e but still only 1 transponder. if i go into any of the other sat scanning options i only see 3 others sats which i scanned for. could it be the lnb or am i missing something simple? help please
                  • eattheliving
                    • 331
                    is it possible to be able to pick up other stas on the arc but still have the dish not set correctly to pick up 28.2e?
                    • dick b
                      • Jun 2009
                      • 2462
                      if you can get 42East 1West and 30West all ok you should get all the other strong sats in between unless there is something in the way.what sats are you getting?if your pole is not 100% plumb you might track part of the arc and no more.and setting up the motor with the wrong lat and the stb with the wrong long/lat will also put it out.
                      • C_S_B
                        • Feb 2010
                        • 56
                        Yes m8, back to dish setup by the sound of it.
                        Best to say what sats you can pick up.
                        SatBeams - Satellite Coverage Maps - Sat Footprint Intelsat 10-02 (Intelsat 1002, Intelsat Alpha-2, Intelsat X-02) / Thor 3 / Thor 5 (Thor 2R) / Thor 6
                        csb
                        ps: the last favourite blue pannel channel list for me was cajton@sats 45e - 30w date 06-02-2010. A little out of date "hint".
                        Or load a new satellites.xml for what you need.
                        "The Transmission of Documents via Telephone Wires is Possible in Principle, but the Apparatus Required is so Expensive that it will never become a Practical Proposition" Dennis Gabor 1962
                        Hungarian-born electrical engineer who won the Nobel Prize for Physics in 1971
                        • dick b
                          • Jun 2009
                          • 2462
                          I"ve just noticed this post mate,if you have gone back to the sat config menu after scanning its all to easy to to remove services by mistake.have you tried a factory re-set then if using usals enter "many sats via diseqc rotor" and go straight to save (do not select any other options) then continue setup .I use line(5) automatic satellite search in the satellite & TP edit menu for sat scanning as you can check that you have what you want after each scan.
                          • eattheliving
                            • 331
                            thanks guy's, just got back and checked. i do get a picture of sorts on 28.2e but it's pixilating. no pic on 7e but sound. 1w seems fine. i think it's got to be the dish again. it's weird tho because when i go into the motor setup i can get 28.2 from the sat list but there are no transponders listed.
                            • dick b
                              • Jun 2009
                              • 2462
                              if you go into the satellite installation & TP edit menu then (4) transponder edit you will get a list of sats on the left and if you scoll down/up and highlight any sat you get a list of transponders in the data base on the right, for 28.2 East I think you should have over 70 if not do a factory reset and see if they come back.
