Technomate TM5400 Plus - FEC query
  • lonexl
    • May 2010
    • 7
    I am new here and hope someone can help. I have a TM5400 super-plus with the latest software (116) from TM website. Am trying to get some channels with frequencies requiring 5/6 & 7/8 FEC.
    My receiver seems to only have 1-4, i.e am getting channels with 2/3 & 3/4 FEC.
    Is this receiver capable of getting / extending FEC (e.g by manually overriding) or does this mean I need a new receiver with such facility?
    PLEASE HELP.
  • mdt
    • 3034
    does the tm5400 not select the fec automatically? welcome to dk. regards mdt
    • lonexl
      • May 2010
      • 7
      Thanks for your reply. Not to my knowledge, when i was setting up channels, had to change the FEC setting manually between 2/3 N 3/4 to get as many channels from two different satellites as i have two lnbs. the channles am trying to get are from Astra 19E and all the googled frequencies i found are showing FEC 5/6
      • mdt
        • 3034
        i dont own a tm5400 but im 100% certain that it will receive channels using the fec of 5/6 because the bbc/itv use it on 28.2east. have you tried a blind scan? as this should find all channels that are broadcasting. try the blind scan and report back if it works. regards mdt
        • lonexl
          • May 2010
          • 7
          Thanks again, spend the last 30 mins giving it a try with no luck can see new channels in Astra 19E but the ones am after
          • dick b
            • Jun 2009
            • 2462
            exactly which channels are you after fec is auto on the TM, which menu are you in?
            • lonexl
              • May 2010
              • 7
              FTA tquila & I tune via the standard satellite search menu. last night managed to download it via blind search but nothing, just blank screen.
              • dick b
                • Jun 2009
                • 2462
                sorry mate but need to know a bit more,what satellite are you on what transponder/symbol rate are you scanning
                • lonexl
                  • May 2010
                  • 7
                  the sat is Astra 19E, TP is 10862 Horizontal in Modulation: sr: 22.000, FEC: 5/6.
                  Thanks.
                  • mdt
                    • 3034
                    Thanks.
                    that txp has switched from mpeg2 to mpeg4 and has also changed its beam pattern as it is now a spot-beam for the polish state channels(tvp1/2 ect) so is no longer receivable.
                    the fec is 7/8 now aswell. regards mdt
                    • lonexl
                      • May 2010
                      • 7
                      Ahhh well....... .. I tried :-(
