Tm800hd
  • geezeruk28
    • Jul 2010
    Tm800hd
    Hi ,I am trying to put a c-line into a tm800hd .This is what i have done so far ,My box is connected into my router ,i am using filezilla to try to connect to box ,i put in the ip that appears on box and technomate for user but it will not connect .Do i need to use null modem as well .Help please
  • geezeruk28
    • Jul 2010
    any help anyone please!!!
    • sharpman
      • Oct 2008
      • 30
      not sure what your trying to do, but if your going to ftp the box, then you need to give the tm800 a pw EG 0000
      then you could use dream box controll centre
      i have the Tm800HD and had no probs connecting
      • geezeruk28
        • Jul 2010
        I was putting the wrong user name in .I was putting technomate instead of root all sorted now.I don`t suppose you could explain how to put a cline in .Thanks
          No cardshare talk allowed m8. Ask Mr. Google he will tell you
          • digidude
            • 53
            reboot the tm800, look at the display, when it says 'checking key' or 'verifying key' press the button on the right, i think its exit, and itll say miniweb, then give an IP, if it says anything else, power it off and try the next button. enter the IP is gives you into an internet window on your pc, and at the bottom youll see a tab with the name of the cam / emulator youre using, click that, copy your text into the box, click add line, turn off and turn back on
            job done
            I break my stuff, so you wont have to
            If this post offends you, dont read it.
            Warning! May contain nuts.
