help ive killed mt tm5300 super
  • redstealth01
    • 53
    i flashed it with a patch now it wont turn on
    trying to use the darkman loader it just says no comports
  • dick b
    • Jun 2009
    • 2462
    need more info.is this a 1st time patching? what patch are you trying to put in,are you sure its the correct one for your model are you using a proper null modem rs232 cable and where does it say "no comport".
    forced download instructions.
    turn stb off at rear switch,open loader & browse for & load patch click on connect then turn stb on at rear wait for sending erasing writing then finish.box should re-boot and work.keep trying if it doesnt and try the official software.
    • redstealth01
      • 53
      imtrying touse a ubb to rs232
      when i click connect it says no port
      iused the latest magipatch and it killed the stb
      • redstealth01
        • 53
        patch 141 is a killer
        • dick b
          • Jun 2009
          • 2462
          I dont think its the phantom patch 141 thats the problem its more likely its the usb to serial adapter your trying to use unfortunately I have no experience of these but I"m sure someone can advise you.if you get no response from this thread.ask again for usb to serial help.
          • dynamo1
            • Nov 2010
            • 7
            technomate patch
            Hi are you using darkman loader, if so you have a choice of com ports . when you first tryed to load you patch did you see the patch loadind from 0% to 100% if so then you were using the right com. if you can give any more info someone will be able to help
