TM-5200 missing channels
  • tj611
    • Nov 2010
    hi,i hope anyone can help as am getting nowhere with other forums(not on here) i have a tm-5200 on motorised dish installed by pros, recently we lost a few channels screen says no audio/video or bad signal,so i did reset and then scanned sats again no joy,i then did restore channels scanned astra or hotbird can't remember but one of these is where the main channels that have vanished are on,the missing channels came back,however as soon as i switched menu they went again,on some other advice was told to check TP,so started with thor as suggested TP was wrong set on 1 settings i was given should be on 12,however no settings are saving and all sats default to 1,so as main theorys i'm getting is channel frequencies up spout and as i can't get TP settings to save seems pointless to me trying to retune each missing channel,now as engineers where i live won't touch motorised even though only a box issue and the ones who will know they can charge what they like ie over 100 quid,i am wondering if getting a new box that is easier to run and set up will rectify my problem,as having been directed to lynsat or whatever its called really looks like to much for me to figure out anyway,I'm not thick but all getting to fiddly now,and was looking at specs on TM-3000 and looks like a better box for easier installation,also i was recommended by installers on this set-up for what we needed,as had people having a go for having this set-up,so if anyone thinks new receiver better way to go,or an easy solution to rectify on current one I await in hope,TY in advance.
  • dick b
    • Jun 2009
    • 2462
    hello mate,we will try and help.but there is a lot of info to take in at one go as no sat box is plug&play.
    the TM 5000 series boxes are one of the most user friendly around so I"d stick with it for now til you understand sat a bit more.
    in the menus the TPs will always go to the default setting and the no1 tp may or may not be active.you can scroll for an active tp on the second line but if you exit it will go back to the default.
    there has been a lot of high winds lately and its possible your dish may be slightly out.so send dish to 1West (thor) then menu>installation>motorised setting. in the transponder line scroll through til you find 11.325(H)/24.500 this is a BBC world TP.the level and quality bars at the bottom should be in the mid 80s.if this is not so it sounds like your dish may need re-aligning,but if its only slight you can try just resetting in box like this.
    if you are on DISEQC 1.2 in the 3rd line drop down to the move fine line and nudge the dish east/west til you get max reading in the quality bar. then drop down to save>ok.then press the red button on the handset to scan.you will have to repeat this for all sats.
    if you are on USALS in the 3rd line drop down to the position setting line>ok then drop to antenna longtitude and alter the setting by 0.2 degrees at a time east or west until max quality signal is obtained this will not show at once (you will have to exit to full screen each time for the changes to take effect)then return to the motorised setting menu,once done you will not have to do this for other sats as on usals this will be automatic.but you may need to re-scan each sat.hope this helps and I"ve also sent a motor setup guide if needed.
    if any thing is unclear just ask.
    • tj611
      • Nov 2010
      To Click B
      HI,tried all that and as quality never changed level was 87% constant, quality fluctuated between 19 and 22% so i guess i need an engineer ,know any reasonable priced ones in Swansea??LOL
      THANKS FOR HELP
      • dick b
        • Jun 2009
        • 2462
        you dont neccessarily need an engineer as most reasonably able DIY people should be able to follow the guide I sent.and the elevation is probably still ok.
        • tj611
          • Nov 2010
          unfortunately if it involves the dish,me and partner unable to do,as he disabled,and is on a six foot scaffold pole and no way in hell i'm getting up there,,i'm getting some guy to come and do free quote,i'm sure we'll get sorted one way or another,unfortunate i couldn't sort through receiver,but hey ho,only other half grumpy as for him,thanks for info though as may help if i have to keep hunting for someone,but ladders and me don't go otherwise i would have been up there,i may consider though if i don't get a fair quote
          THANKS though
