Can you please tell me how to use the patch on TM 3000D through computer. as you now tm 3000 d dosen't have a USB port. so how do you patch it using RS-232 cable
Please help!!
you need a loader from the download center(link just above your post) and a proper NULL MODEM patch lead.
turn stb off at rear connect null modem cable to the rs232 ports on your box and computer download and unzip loader & patch.
open loader on software tab & browse for & load patch.click on connect then turn stb back on.wait for sending-erasing-writing then finish and box should re-boot.(I"v found the loader) you use the same loader for inputting keys just click on the "tab" for key and select your model from the list.
if your computer doesnt have an rs232 com port you will have to use a usb to rs232 converter.but these can be tricky to get working and I have never used one.but others will have.
