13 E
  • jc2
    13 E
    Got a fixed dish on 13 E , is it worth patching a 5200 super series,will I be able to unscramble any extra channels ang get anything other than the FTA I already have?
    Cheers
    JC
  • dick b
    • Jun 2009
    • 2462
    not much on 13E a few rai channels and tv globo,
    • jc2
      Thanks for your help so far ,because of house and current dish position I can only go further east to pick up satellites, so would it be worth picking up a motor?
      And whilst I am on here, if I did fit a motor, does it run off the standard coax cable I have already run, or do I need a seperate cable to the motor????
      Any comments welcome.
      JC
      • dick b
        • Jun 2009
        • 2462
        any diseqc motor just runs off the one co-ax cable and are simple to install.its cable to motor from stb then a short cable from lnb to motor.as you can only go east you would still get quite a few of the main sats 13E,16E,19E,23.5E 28.2/5E,39E,42E.with a bit of standoff from your house you may be able sneak abit further west but you would have to check that out.have a look at this guide for std TM setup you would be best to use 28.2East as your target setup sat as 1West would be no good for you.IF you do motorise you could always get a spiderbox as you will get a wealth of channels open on 13E,16E,and 19E.
