Technomate Softcam Keys **Discussion Thread**
  • digicon
    • 8261
    #31
    Originally posted by mickky3
    19.2 east in that update thanks.?
    If the keys have changed then yes if not then no the only major change was to Bulsat on 39? east
    Last edited by digicon; 22 October, 2013, 01:04. Reason: Hellasat has moved back now
    • mdt
      • 3034
      #32
      Originally posted by digicon
      If the keys have changed then yes if not then no the only major change was to Bulsat on 29? east
      when did hellassat move to 29east? , @mickky3 if you are refering to T**sat then no its still down on non @kyngteam boxs atm.regards mdt
      • agathe79
        • Oct 2013
        • 5
        #33
        Where's the best place to get the latest phantompatch and softcam keys for my 5402HD M2? as the TNT SAT channels are scrambled again
        • digicon
          • 8261
          #34
          patches can be found on the download centre: http://download.for-better.biz
          and softcam keys can be found in this very sub forum: http://www.digital-kaos.co.uk/forums...3/index10.html
          • agathe79
            • Oct 2013
            • 5
            #35
            do you need to run the latest firmware update again (I have done this once) and then the patch and softkeys when updating the softkeys
            • digicon
              • 8261
              #36
              No you just install the latest softcam.key file if your running the latest patch then no need to do it again.
              • agathe79
                • Oct 2013
                • 5
                #37
                Still don't get TNT SAT channels anymore, confused now, when I go to usb / File Transfer option, It has options to Load STB and Load Keys, do I do this or
                in which case another file appears or do I just press Okay on the Patch and Softkeys files?
                • digicon
                  • 8261
                  #38
                  As i explained previously you only need to load the softcam.key file via USB you do not need to patch your box again if it has already been patched.
                  You wont get the TNTsat channels at present as something has changed in the encryption which means a new patch will have to be developed to open just these channels again
                  • popol40
                    • Mar 2013
                    • 12
                    #39
                    Hello, are there any change in the keyd for ORF, i no longer received "Kabel eins classics" all other ORF are o.k.
                    Sory forr my bad English.
                    many thanks i advance for your help.
                    • mdt
                      • 3034
                      #40
                      all ok here... 12.545.H.22000.5/6 DVBS/MPEG2 watching "the warriors" at the moment baseball furies ,regards mdt
                      • footycard steve
                        • 778
                        #41
                        are we waiting for a new softcam my bulsat was down last night
                        • digicon
                          • 8261
                          #42
                          Apologies Steve new softcam is there now.
                          Regards
                          • mickky3
                            • Feb 2013
                            • 16
                            #43
                            any body a patch for 4.8 east tv 10?
                            • mdt
                              • 3034
                              #44
                              no m8, tv10 isnt available via softcam/rom and the only way you will get it is via an official card or via methods we cant discuss that use your lan connection. SVT1,2,24,Kunskapsk****en are available on the TM boxs right back to the very old TM1000D fta,,regards mdt
                              • bigpete
                                • May 2010
                                hi folks im new iv got an Technomate 1000D Super and just wondering what was still working on it any help cheers
