newbie to uno
  • homer41
    • 207
    newbie to uno
    hi guys just got my uno pleased with the speed of it flashed with vix image. anyone know how to add/install cccam?
  • father ted
    • Feb 2008
    • 1389
    you have to download it and put it into the temp folder then load it that way i dont use vix but there is a right way to do it ,at one time you could just ftp it into the image but now you have to do it the right way
    • dell_xps
      • 2558
      Look for the ipk file, then tranfer it the temp or etc folder I think,
      then locate the ipk installer on yer vu, click install, then copy across your cline to the etc folder:-)
      • RuberDuck
        • 1724
        download the cam from here ( 4th one down )
         http://www.4shared.com/dir/wnyHV50A/VIX_CAMS.html
        FTP the .ipk file you download ti /TMP on your receiver and press BLUE button > VIX > install local extension. you should then see the .ipk file highlight it and press the green button to install.
        now once installed copy your CCcam.cfg file to /etc on your receiver. now presuming you have the nessecary details in the CCcam.cfg file press BLUE button > softcam manager and select CCcam to active and autostart.
        that should be all thats needed.
        • homer41
          • 207
          cheers for all your help guys sorted in the end. now to add bouquets and picons. can i use sgt flip flops bouquets and picon pack on my vu+??
          • dell_xps
            • 2558
            Yes :-), you sure can.
            • freck
              • 1076
              I'd recommend that you get the Tunisiasat addons manager ipk file and install it.
              Youll get all your cams/setting and various tools straight to your box.Might be in the downloads section but deffo here somewhere....if i come across it ill send it.
              Freck
              Here you go...its an older version but you can update it when youve installed it
              • homer41
                • 207
                using sgt flip flops and his picons works great
                good box too
